Question about Clopay Snowmist White Garage Door Touch Up Spray Paint 4.5oz 0330506
Clopay snowmist white spray paint
Where can I get it?
Can i paint my garage doors?
Clopay's steel garage doors can be painted with any high quality exterior latex paint. Wood garage doors must be painted/stained on all sides prior to installation. Most models are available factory primed. Clopay recommends wood garage doors be re-painted every 1 to 2 years (more frequent refinishing may be required in high moisture areas).
Oct 02, 2014 | Building Materials
Oil from a reed diffuser spilled all down my bathroom wall on Benjamin Moore paint how can I remove the oil thT stained the painted wall
I would wipe it down with a degreaser like Simple Green, or paint thinner
The paint is ruin after cleaning it you will need to paint. You can prime the area with a oil base white primer in an spray can
Jul 23, 2014 | Tools & Hardware - Others
How can I deep-clean or spruce up the white Dangari resin arm chairs?
Try using Zep shower cleaner..Wet the chairs, spray it on and let it sit for ten minutes and wash it off with a pressure washer. Paint is not going to stick for very long on resin.
May 19, 2014 | Evolutif Dangari Resin Outdoor Dining Arm...
Remove paint from lcd screen
Try WD40 sprayed onto a cloth and then rub the white streak gently.
Oct 13, 2012 | Sens S1901DVD 19 LCD TVDVD Combo
I have puma takkie, the ferarri edition and its white in colour so i sprayed it black.Ineed to know what is the correct paint for the shoe.
Pretty much the correct paint is the one that sticks. I have used Krylon spray paint on some cheaper shoes but there are actual shoe dyes from shoe findings companies you can use..
Apr 20, 2011 | Puma Clothing Accessories
How do i restore the surface of my outdoor ping pong table
Use painters tape to cover the white lines of your table tennis table.
Use sandpaper (150grit) to smooth the surface. This will level any bumps or scratches. Fill deep cracks with wood filler, let it dry and sand the table again.
Make sure that the table is clean before you begin the painting procedure.
Use chalkboard spray paint about 8 inches away from the table and spray each side. Allow 8 hours for the paint to dry then repeat with another coat. Next day, repeat the process so you have 3 layers of paint. Chalkboard spray paint helps the ball bounce to the correct height and speed.
Remove the painters tape after the last coat and allow the table to dry for at least 24 hours.
Hope this helps, vote me if so :)
Jun 30, 2010 | Kettler Stockholm Outdoor Table Tennis...
Did a kitchen make-over and want to change our white fridge doors to black-can we spray paint them?
Yes, you can buy black appliance paint in a spray can. Do a good prep job first.
On site that sells it...
http://www.globalindustrial.com/p/maintenance/paint/aerosol/krylon-appliance-epoxy-paint-black?utm_source=google_pr&utm_medium=cpc&utm_campaign=Aerosol-Paint-google_pr&infoParam.campaignId=T9F
Feb 28, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Rust on outside of freezer door -- is there an epoxy or white coating to cover over the rust?
You can clean off using a green scrubbing bad and some brasso all at wall mart then buy a can of spraypanit and spray it with food grade paint by Krylon paints also at wal mart. The paint will seal it and keep it from comming off.
Nov 12, 2009 | Amana ABB1927DE Bottom Freezer...
Clopay Snowmist White Garage Door Touch Up Spray Paint 4.5oz 0330506 Logo
112 people viewed this question
Top Clopay Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Clopay Air Tool and Compressor Expert? Answer questions, earn points and help others
