Question about Panasonic TC-P42X5 42" 720p Plasma HDTV TCP42X5
Was working fine,now will not turn on - Panasonic TC-P42X5 42" 720p Plasma HDTV TCP42X5
After turning on my my acer 2300 its boots up fine but the fan only works for a few seconds then stops and then does not work at all
Normally if the fan is bad and failing the laptop will run hot (overheat) and shut down. If yours is not doing that, then you are fine. Sometimes the fans will turn on and off as needed.
Apr 01, 2012 | Acer TravelMate 2300 Notebook
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
1998 hd 1200 sportster turn signal quit working
check the wiring under the rear tire. you probably tore the wires. if that's fine. do your flasher work? if they do then double check the bulbs. if they're fine them it could be the tsm ( turn signal module ) Only consider replacing that if the wiring is fine and the turn signals worked fine before
Jun 23, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
1999 Nissan Altima GXE Turn signal problem
you have a busted bulb, your hazard may be working fine but the bulb is double contact so one part is working and the other is not. just check which bulb is busted.
Apr 20, 2009 | 1999 Nissan Altima
Turn signals and ac stopped working at the same time
don't know if they are related. as for the turn signals check the flasher. there should be 2 of them.one for the turn sinals the other for the emer. flashers
Mar 11, 2009 | 1999 Jeep Grand Cherokee
Turn signals
replaced turn signal flashers and muti switch turn signal still won't work Why?
Nov 08, 2008 | 2000 Jeep Grand Cherokee
I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay...
I have a Toshiba C/X3030D television was working fine yesterday when turned off. Turned on today and digital channels will not work. Analogue is fine,Digital menue is just flashing up and will not stay open so can not reset television. Any one with ideas as to what has gone wrong?
Thanks
Jul 11, 2008 | Televison & Video
Yamaha HTR-5940 turns off after one second.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Jun 21, 2008 | Yamaha HTR-5940 Receiver
Panasonic TC-P42X5 42" 720p Plasma HDTV TCP42X5 Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
