Question about Hobart Ovens
I HAVE A HOBART CN85 ELECTRIC CONVECTION OVEN BLOWER WORKS BUT HEAT LIGHT ONLY BINKING ON AND OFF WILL NOT HEAT TO TEMP.
I HAVE A OLDER 220 ELECTRIC HOBART CONVECTION OVEN BLOWER WORKS HEAT LIGHT ONLY COMING ON ONCE AND A WHILE FOR A FEW SECONDS WON'T HEAT TO TEM.
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: kitchenaid KEBC177 electric convection oven will not heat
    This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
    The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
    The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
    This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
    For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
    Posted on Dec 09, 2008
    SOURCE: decor oven
    I have a dacor oven and I have the same problem. I called the Manufacture and they said it was due to the Heat Sensor in the panel. The Sensor has been tripped and needs to be reset. Now I am in the process of finding out how to get into the panel.
    Posted on Jan 22, 2009
    SOURCE: Oven won't heat.
    Thanks for the tip. Had the same problem, everything seemed to work except for the heating elements. Removed the vent cover inside the door just below the control panel. Found the reset button and also found one of the large black power wiires had come loose from its connector. Turned off the power at the breaker box, checked for voltage with a meter and re-attached wire connector with insulated pliers. Oven works now. Lets call this failure "poor workmanship at Dacor".
    Posted on Feb 03, 2009
    What causes a duke E101 convection oven to not cook evenly?
    If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
    Fan and blower problems tend to be a bit more common with convection ovens.
    Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
    I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
    It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
    Apr 27, 2014 | GE Ovens
    Hobart convection oven
    You either have something hitting the convection blower wheel or the bearings in the convection motor are shot.
    Feb 17, 2014 | Ovens
    Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
    it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
    Jul 28, 2012 | Dacor Ovens
    Not heating
    Before buying any parts, check for proper voltage to stove and receptacle. On the side of the oven is an opening that keeps the controls cooler. If it is blocked, the temp control might be malfunctioning. Something as simple as cleaning that up might cause it to work better.
    May 17, 2010 | Hobart HEC20 Electric Single Oven
    Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
    Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
    Apr 09, 2010 | Hobart HEC501-240V Electric Oven
    On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
    There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
    Oct 12, 2009 | Amana AOCS3040 Electric Single Oven
    Oven does not heat
    I would suggest that you check the oven element, it sounds as though it is faulty to me.
    Dec 14, 2008 | Ovens
    Ovens Logo
    97 people viewed this question
    Top Hobart Ovens Experts
    Dan Webster
    Dan Webster
    joneable
    Level 1 Expert
    Gil Shultz
    Are you a Hobart Oven Expert? Answer questions, earn points and help others
