Question about Lenovo IdeaPad Y570 15.6
A network cable is not properly plugged in or may be broken
Apparently my network cable is broken or not pluged in properly what is this network cable and how do i fix this problem
The LAN cable is a CAT5 network cable.
For further details check out this WEB site.
http://en.wikipedia.org/wiki/Category_5_cable
Apr 02, 2013 | Toshiba Satellite L305D-S5974 Laptop
Anyone know the proper order for the 8 wires in a hitachi network cable to match a raymarine network plug?
If your network-cable has "male" connectors at both ends, and the order of the wires is the same at both ends, i.e., a "straight-through" cable, then the network-cable will work fine.
Oct 04, 2010 | Raymarine Computers & Internet
Router is not reading cable.
I'm assuming that you have it either connected to a computer and the wall properly. You may have to have some sort of machine working and connected to the router in order for it to acknowledge the cable. Make sure that everything is properly plugged in. Try and turning off your router for one minute and then give it another go. Try troubleshooting by unplugging and reconnecting wires to the router. Are you using a Cable or DSL Internet Service Provider?
Dec 24, 2009 | Dynex 7' Cat 6 Network Cable - Gray
My laptop will not recognize the router and will not work wirelessly. Also, the connector where I would plug in the cat 5 cable to work as wired is broken, so I NEED it to work wirelessly, How do I do...
check the wireless adapter. Is it working or not ? For this you will need to go to the device manager. When you try to connect to the wireless network . Do u get any message ? Check the settings of the router also. Is there any other computer online wireless ? if there is other computer online then the router must be working properly. Click Here for step by step solution
Nov 15, 2009 | Intel PRO/Wireless 3945ABG Network...
OK I had the RCA DMC425 plugged into my laptopalright easy.I unpluggled eveything turned off the laptop so i can clean around my computer desk.When i finished i plugged everything back in and soonenough it...
troubleshooting a network is a multiple step process.
1. Establish that your modem is working properly, and plugged in. As per the diagram shown here:
  • Your "Cable link" light should be on (signifying that the outside cable is properly connected to the router)
  • Your "Internet" light should be on (signifying you have an established Internet connection)
  • And, most importantly, your "PC Link" light should be on (showing that at least as far as the modem is concerned, it is detecting that the computer is plugged in to it.
2. double check to make sure that the network cables are seated properly, and plugged in all the way. the PC link light should give you an indication for modem-side- the LED light around the network cable jack on the laptop should give you an indication PC-side.
3. check on your laptop for any security software that may restrict new networks from being detected and disable them to test. For example, Symantec or Mcaffee Firewall can sometimes block a "new" network from being detected.
4. Completely shut down the laptop and unplug the power cord from the modem. Plug the modem back in. Wait around 3 minutes for the modem to initialize and do it's thing- then turn on your laptop and see if this resolved your issue.
If this doesn't work, you may want to try other things, such as resetting your network, and removing/re-installing your network adapter drivers.
Aug 03, 2009 | Acer Computers & Internet
Modem are not connect in reliance netconnect
if you can, remove and reinstall the modem and/or the program.
look at the cable fittings and see if something is broken or bent.
try your local geek network online.
go to your usb port settings and see if it is reading the proper link to your modem and see if your modem is recognized.
may be the network settings you have. in conflict with your modem and network router.
May 21, 2008 | Computers & Internet
Lenovo IdeaPad Y570 15.6 Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
