Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I need instructions for wiring a honey well thermostat Model# T8132A1007
2 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: digtal thermostates
Give this number a call if you are in the US, 800-341-0110. You will need the COMPLETE model number not just 230B. Something like YRTH230B1009. They can link you a manual via email.
Posted on Nov 15, 2007
Honey wire
Look for reset button push in and try to Program if this doesn't work time to replace T-Stat.
Jul 05, 2013 | Honeywell Programmable Thermostat Heater
My central heating is not working. ihave honey well mercury 20v thermostat
You can easily check the thermostat by jumping across the R & W terminals. If the furnace fires your problem is the thermostat. If not, the issue is with the furnace or the wire between the thermostat and furnace. I can walk you thruogh a dignostic check but you will at least need a volt meter.
Mar 05, 2013 | Heating & Cooling
We had a Honey Thermostat model # TH4110D1007 installed in our house, our technician did not leave an instruction manual with it and we don't know how to run it, can we get a website to download a...
yes just go to honeywell site. The address is inside the thermostat. Just pull the front part of the thermostat off and read the lable inside. Hope this helps.
Sep 06, 2011 | Honeywell Heating & Cooling
Trying to put new honey well thermostats on but, old cozy thermostat only has two wires. Wires are not labeled, what are the wires?
on a 2 wire t stat the wire color does not matter much .but on the thermostat you want to use rh and w connection point.other terminals are for fan and cooling
Jan 29, 2011 | Cozy (W352E) Heater
I need help installing a honey well thermostat model#rth3100c1002
Just follow the instruction as per in pdf format as follows:
customer.honeywell.com/techlit/pdf/60-0000s/60-0830.pdf -
Dec 31, 2010 | Honeywell Heating & Cooling
I have a boiler system that was turned off at the thermostat for about 5 min. when turned back on it never clicked on again it has a new honey well aquastat relay, new pilot and prob only three months old....
Take off the thermostat and jump the red and white wires together. The boiler should fire up. If not, you will need to check if the boiler has power to the control. It could be a fuse that burnt.
Feb 14, 2010 | Honeywell Programmable Thermostat Heater
Cannot get new thermostat to work
didn't wire up correctly or if purchased a digital one didn't set up correctly, look at the instructions and should tell you how to set t-tstat up or if you have to remove or move jumper.
Apr 23, 2009 | Heating & Cooling
I have amanual honey well and I want to change it to a programable honeywell but the two wires on the manual thermostat are not labeled, so I don't know where to connect the wires to in the new thermostat
Wires for thermostat control circuits are normally color coded. Check for proper connections at the furnace and connect the same colored wires that you find at the furnace to the like lettered terminals on the new thermostat. R to R, W to W , Y to Y , ans G to G. R is for power to the thermostat, W is for heating, Y is for cooling and G is for furnace fan operation.
Nov 14, 2008 | Honeywell Heating & Cooling
Digtal thermostates
Nov 13, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
78 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
