Question about Dishwashers
Fuse blown LG circuit board 6870ED9001C
Main circuit board fuse blown due to contact with wire (accident)
  • 556 Answers
SOURCE: Sylvania (ProView) CL2072b Circuit board fuse
normally it is
3AMP/250VOLTS.
good luck.
Posted on Oct 12, 2007
  • 313 Answers
SOURCE: dewalt dc011 ! wont charge batteies
send your radio for repair. till the guys at the service for grc repair cost. very economical rather than you do it your self if you are not sure of the problem. radio need 3 circuit borad or also a charger
Posted on May 27, 2008
localwonder
  • 6784 Answers
SOURCE: My LG refrigerator has a blown fuse on the circuit
Yes. This fuse is replaceable, but, you will heed to De-solder the contacts, in order to remove the damaged fuse. this can be very challenging. If you are not an avid user of a soldering iron, i would just simply replace the board. If the soldering is not done correctly, this will cause the board to short, causing a spark.
I would , also, verify that the fuse is available for a non technician to purchase. Most vital components will not be available for purchase, if the purchaser is not a certified tech.
Posted on Oct 21, 2009
Testimonial: "Very helpful"
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
  • 7 Answers
SOURCE: LG Frig LFC23760ST 3 Door French Refrigerator : No power!
LG LFC23760ST
I recorded a 2 part movie clip on how I repaired the blown fuses on my LG refrig's circuit board.
Posted on Mar 13, 2011
Is there a fuse for lg 50pw350
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time; especially to Plasma TVs.
Sep 07, 2014 | LG 50 50PW350 50 3D Plasma TV
On a LG LSC26905TT need circuit board location to replace fuse
How do you know the fuse has blown if you haven't accessed the board? Check the mains incoming power first, and power to the compressor. The pcb is usually in the top above the door frame.
Apr 27, 2014 | LG LSC26905TT Side by Side Refrigerator
Fuses keep blowing for my flat screen tv
Short circuited component/s at its main power regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | LG 42LC2D 42 in. LCD HDTV
My LG wired remote control has no display - just turned off - seems to have no power - circuit breaker has not tripped? Any advice????
sounds like blown fuse in low voltage control wires. Due to short in wireing usually a wire rubbing against somthing due to vibration. Coating starts coming off wire then touches metal. If fuse replaced and it runs it will most likely will happen again unless short is located.
Aug 29, 2012 | LG Heating & Cooling
We have a King Pellet Stove 1 year old. Fuses keep blowing. Have replaced ignitor and fuses several time. Is a surge protector the answer or is it the circuit board? Thanks!
Please understand the reason for fuses blown:
1. High amphs of the main part in the unit. 2. Short circuit 3. Loose wiring. 3. Wire contacts corroded due to rusted or dusty.
Dec 12, 2010 | Heating & Cooling
LG LFC23760ST
Mar 31, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Machine does not turn on but circuit board has power I think prob is circuit board
I would bet you have a duct fuse blown due to some sort of air flow restriction. Most duct fuses have small wires, do not carry a heat load, and are in the same circuit as the door switch. When drum temp rapidly rises to 350f the duct fuse melts and stops the appliance before dangerous situations occur.
Mar 03, 2010 | Dryers
I have an LG WM2277HW washing machine. My wife went in this morning to do some laundry and the thing is completely dead. No lights or signs of life. I checked the house circuit and the power to the...
Make sure the noise filter connectors are clean and connected properly. Get yourself a multimeter and check the voltage both on the load side and line side of the noise filter. It should read the same at 120VAC. The noise filter is the board before the main board. Replace it if the voltages on its load and line side are not the same.
The main board is not serviceable and must be replaced if faulty. It has a fuse and if it is blown, the main board is probably faulty. Look at the two brown capacitors on the top left of the main board. Next to it is a heat sink and to its right is a white "fuse-like" component with silver ends. That is the main board fuse. If it is blown, disconnect all the connectors from the main board except the one connecting it to the noise filter. Jump a single thin strand of wire in place of the fuse and apply power to the machine. Check if the power LED indicator on the main board lights up. If it does not, the main board is dead, replace it.
Please do not hesitate to update me about your findings above for further guidance if necessary.
Jan 12, 2010 | LG WM-2277HW Front Load Washer
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Mar 04, 2009 | LG 37LC7D 37 in. LCD HDTV
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
Owen Barnes
