Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Richmond 6g40pv heater flashing 2-3 trouble code
2 Suggested Answers
SOURCE: My Richmond tankless water heater
Richmond is Rheem.
Following links are meant to assist resourceful do-it-yourselfer solve long term maintenance issues that tankless pose.
Error 76 is communication fault with remote control.
Check following links for Paloma 'Rheem" error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
Best place to start is your manual. Following link show typical Rheem manual with the words troubleshoot and maintenance throughout manual.
Read manual several times before buying product to see yearly maintenance requirement and complexity of tankless water heaters.
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Contact Rheem: they will usually kick you back to local service technician.
http://www.rheem.com/Contact.aspx
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Rheem website is not easiest to navigate, but manuals appear for current models.
Read other Rheem questions at fixya to gain wider experience with potential problems and solutions.
http://www.fixya.com/tags/rtg_74pvn
Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum: This is where I go to catch up on latest info in fast-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
I have a Richmond tankless water heater and it has L1 error code...can somebody help me with this?
Might be able to help. Except L1 does not show on any error code file.
Copy following link for Rheem Richmond Ecosense etc computer water heater troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Are you sure the error is not IL? Delime tankless.
Or UL flashes and indicates reset.
Or CL flashes and indicates fault history is cleared.
Or error 11 combustion failure? Call for service.
Or P1? Low water pressure, clean water filter check for leaks and crossover caused by bad single-handled faucet cartridge.
I recommend calling Rheem to find local technician who is qualified to work on tankless computers. Tankless are not ordinary water heaters, and they require continual maintenance to avoid common error codes, especially as unit gets 2-3 years old, after warranty has expired.
The required maintenance and expense of repairs, and general fact that people cannot make their own repairs, make tankless computers a bad choice for heating water.
If unit is 4-5 years old, it might be best to install tank-type heater for $385 from Lowes and cut losses.
Gene
h
Aug 08, 2013 | Rheem Richmond Encore Tankless Nat Gas...
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
Richmond power vent 2 flashes code 4-4
Sounds like a pressure switch or simular sensing device that is not proving positive, thus a possible vent blockage or defective sensing device.
Mar 05, 2013 | Water Heaters
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Our Richmond Tankless is showing a reading of a C2 error code. How do we fix this. Why is it doing this?
Before calling service technician, open following link for Richmond/Rheem troubleshoot resources including Rheem chat.
Error codes are considered start place for troubleshooting.
C2 11 is 'No ignition' or 'Gas is inadequate' or 'Ignition failure'
Error C implies ignition rod
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jun 18, 2011 | Rheem Tankless Hot Water Heater...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
May 16, 2010 | Rheem Tankless Hot Water Heater...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
16 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
