Question about Kenmore 25.4 cu. ft. Side-By-Side Refrigerator with PuR Ultimate II Ice and Water
Ice dispenser My ice dispenser quit working. Make hum but no Ice dropping or crushing.
  • 5 more comments
  • Anonymous Dec 06, 2007
    repair ice dispenser
  • NotSoHandyMn Dec 08, 2007
    How do you remove the ice maker motor? Owner's manual does not cover this.
  • Preserve Dec 14, 2007
    Something "similar" with ice maker, but, have already taken out the bins because of large chunk, cleaned that out and seemed fine, but, ice does not release. We can hear the ice dropping and then it builds up. Seems that maybe whatever part is there to "release" the ice is not letting it through. ALSO, when fridge was new, you could hear the program change when buttons pushed now we hear nothing.
    Thanks
  • Yova May 20, 2008
    I have an LG side by side LRSC-26925SW, the ice is not released from the ice dispenser, you can hear the ice building up but the little flap door type thing doesnt open to let the ice through.
  • thefav May 11, 2010
    Ice dispenser will not work, checked micro switch, replaced motor. problem persist, any suggestions?
  • Anonymous Mar 30, 2014
    crushed ice not working
  • Anonymous Mar 31, 2014
    door dispenser not working
  • 709 Answers
Hi Wilday1, Sounds like you have a possible defrost malfunction. In this case the Ice maker motor may have become iced and cannot turn the auger. Tell me if you have frost buildup at the back of the frezer and ice crystals on the auger drive. If you do , then you need to remove the Ice makers motor and allow it to thaw and defrost itself. be sure it is completely dry before putting it back in. I hope this helps.
Posted on Oct 08, 2007
  • Greg Stokes
    Greg Stokes Oct 08, 2007
    Also , Some time you may have had the freezer door not sealing well and the ice in the bin could have began to melt, then refreeze as a large chunk. In this case you need to remove the ice bin from the freezer and remove the big chuncks.
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not dispensing ice out front
could be frozen auger motor, try turning motor by hand.
May 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
Kenmore 25.4 cu. ft. Side-By-Side Refrigerator with PuR Ultimate II Ice and Water Logo
257 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
