Question about Brother PT-1750 Thermal Label Printer
Words are printed backwards
Can not get words to print correctly
4 Suggested Answers
JMuskovitz
  • 135 Answers
SOURCE: printer prints backwards/upsidedown
This sounds like an advanced setting on your printer setup. When you get to the print dialog, hit Properties for your printer, then look around there for a "mirror" or "reverse" setting. Different printers use different drivers, so your configuration options are difficult to predict.
Posted on Apr 18, 2007
Mix-it-up
  • 832 Answers
SOURCE: Can't print documents from Word.
Did you do a test print by pressing ink testprint etc.? Do you have all colors incl. BK? If yes, check the printersetting WITHIN Word. Is the mfc the printer to be recognized by Word or is it another one? If you miss the bk upon the test sheet try to clean the ink cart by help of pressing ink arrow-down-button (cleaning) and (blue) start mono. If there is no or not enough ink check the cart. In case you use third party ones, use an original brother cart and do the cleaning twice. Third party carts do make a lot of trouble due to malconstruction!
Posted on Oct 10, 2007
yooperbud
  • 8637 Answers
SOURCE: Printing on a MAC returns mirror image printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Why Why is my hp photosmart C5580 All In One printer printing words backwards
May i know which application are you using to print from ?
I guess "Mirror printing" is enabled , hence you are getting its desired effect.
Open a Notepad and print, let me know if issue still persists.
Aug 22, 2012 | HEWLETT-PACKARD Photosmart C5580...
Printer prints information backwards. Example: In a document, when the word "directions" is typed and ready to print , when it prints out, the letters are printed backwards (i.e. snoitcerid).
somewhere in your property settings there is a checkbox called "mirror". It sounds like this is in the checked position. Uncheck the box and try again. GOOD LUCK!!
Oct 14, 2009 | HP Officejet J5780 All-In-One InkJet...
Source code of a program
import java.util.*;
public class StringReverse {
  public static void main(String[] argv) {
    String s = "Support Tech Problem";
    // Put it in the stack frontwards
    Stack myStack = new Stack();
    StringTokenizer st = new StringTokenizer(s);
    while (st.hasMoreTokens()) myStack.push(st.nextElement());
    // Print the stack backwards
    System.out.print('"' + s + '"' + " backwards by word is:\n\t\"");
    while (!myStack.empty()) {
      System.out.print(myStack.pop());
      System.out.print(' ');
    System.out.println('"');
Apr 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
All printed matter comes out backwards.
Turn off mirror printing:
R-Click on printer
Properties --> Printer Preferences --> Advanced -->
+Printer Features - Mirror Image: OFF
Jan 12, 2009 | HP Officejet Pro L7650 Printer
Hp 3915 printer won't print word docs but will print all else
check MS Word's print setup (File -> Print Setup) and make sure it's set to the correct printer.
Nov 20, 2008 | HP Deskjet 3915 InkJet Printer
Printing documents backwards
You must have set it to be a mirror copy in the print settings.
Oct 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printing Backwards!
this is when it is mirroring itself. Ours did this and we uninstalled and reinstalled the software and it worked fine after that. I don't know what else you could do I am sure some of the experts will but I do know this worked for us.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
Poor quality impression
I am supprised your repairman couldnt fix this, either the hammer is binding or the V 1 resistor on the logic board needs adjusted I do this repair in my shop quite often.
Jan 18, 2008 | Swintec 7040 Typewriter
Printer prints backwards/upsidedown
Apr 18, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother PT-1750 Thermal Label Printer Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
