Samsung le40c530f1w not turning on 3volts on av board computer chip not turning on.
Samsung tv wont turn on?
hi on some samsung tvs when the caps go it can take out the epprom chip on the mainboard you can short the chip out to reset or replace the chip, thanks
shaun
Mar 10, 2017 | Samsung Televison & Video
SAMSUNG LED Syncmaster sa300 monitor no response
Oh dear, thats common problem happenned on sa300 series ,
if you luck it can be fixed by update your monitor firmware , other final worst possibility is you must change it bios chip and or eeprom chip.
Aug 16, 2012 | Computers & Internet
Samsung le40c530f1w remote not working
Check the remote control first for its infrared emission. If remote control is OK, the remote sensor inside your TV will have the fault. It is a three terminal device, can be located just behind in infrared window at the front panel of the TV. You have to open the TV, and take out the front panel printed circuit board to access it, and to replace it. For more details visit this site, by typing in 'electronicshelponline' It is a blogspot site, have all details about how to check and clean the remote control. The site name is Electro-help. It is in English language.
Jun 20, 2012 | Televison & Video
Good evening i have just purchased the Samsung
you have to use an antenna or cable feed to your tv to enable to watch tv on tv mode.
Jun 10, 2010 | Televison & Video
I have an acoustic solutions tv, i use a hdmi lead to play the ps3 on it. The volume is not working tho, the hdmi lead works on other tv's and the ps3 volume is turned on, but i cant get the volume to work...
check the hdmi out with another device that takes hdmi, the hdmi system works on its own from the av board side of the av board. has its own settings. then main board will have a large chip on the board and this is the hdmi control chip. these can go on there own and not afect any other part of the tv
Jul 21, 2017 | iLO LCT32HA36 Television
2 pixels turned white
Here is the solution, it's on a forum. You problem is a faulty DLP chip on the DMD board:
http://www.avsforum.com/avs-vb/showthread.php?p=16445994&posted=1#post16445994
samsung claims it is not a problem, but I've seen HUNDREDS of people with this problem. A facebook page has been made to attempt to get samsung's attention:
http://www.facebook.com/home.php?ref=home#/group.php?gid=76261763079&ref=mf
May 11, 2009 | Samsung Televison & Video
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
