Question about OKI Office Equipment & Supplies
Oki C610 made a pop sound and there is a burnt electrical smell, the wake up light is on, no other sign of life.
Was due to replace the belt unit but have been delaying for as long as possible, could this be responsible for the problem?
Patrillica
  • 141 Answers
SOURCE: Oki c5800 laser printer
http://www.c5800.co.uk/index.asp?printername=C5800&menumode=0&content=C5800downloads
At the bottom you will see the file C58uEN1.pdf
Go to page 89
Posted on Mar 26, 2008
  • 5 Answers
SOURCE: transfer belt for the oki 9300 led printer
Swith off the machine before installing new units. Also check for toner dust on pins and also check to see if the pins are not bent. You can also try leaving the machine switched off for about an hour unplugged from the mains.
Posted on Jun 26, 2008
pineworks
  • 4041 Answers
SOURCE: OKI C8600 Replace Image Drum - 563: K Drum Life
Solution:
  • Power on printer while holding both the + & - buttons simultaneously; release when “OKIUSER” is displayed.
  • Press either the + or – button until “ENGINE DIAG MODE” is displayed; press the Enter button and “DIAGNOSTIC MODE xx.xx.xx” will be displayed.
  • Press and hold both the - & On-line buttons simultaneously until “ENG DIAG LEVEL2” is displayed.
  • Press either the + or – button until “CONSUMABLE COUNTER SET” is displayed, press the Enter button; you are now in the menu to set various consumables.
  • Press either the + or – buttons to scroll through the various consumables, at the desired consumable press the Enter button and the last digit of the count will start flashing.
  • Press the Cancel button to decrease the digit amount or press the On-line button to increase the digit amount; press the + or – buttons to move along individual digits in the count.
  • Once the count is at the level you desire, press and hold the On-line, Cancel, & Back buttons simultaneously until the “*” reappears next to the count; consumable’s count are reseted to the number you specified.
  • Press the + or – buttons to move to the next consumable and repeat at step 5.
  • Once all consumable counts have been set to desired amounts that are below their end-of-life thresholds, you can use the Back, +, & - buttons to exit through the menus
  • until “INITIALIZING” is displayed.
Posted on Jan 30, 2010
  • 13 Answers
SOURCE: My Oki C5800 says
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Posted on Jul 06, 2010
SOURCE: we have replaced the belt
ihave hp printer
it gave error 54.2
and error 49 what can ido
Posted on Jan 02, 2013
1998 Duo-therm Brisk Air compressor not coming on. Smelled of burnt electrical when first happened. How do I check to see what the problem is?
Burnt smell is not a good sign. If your compressor is not turning and the clixon does not shut off power you will hear a humming sound and start smelling as unit burns it self up. Chances are your compressor has seized and needs to be replaced.
Jun 11, 2016 | Brisk Air Heating & Cooling
Unplug the printer immediately. Popping soounds followed by burning smells indicate an over voltage issue on either the LVPS or the HVPS.
Nov 18, 2013 | Oki Electric Industry C8600n Led Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
Low humming noise and burnt plastic smell coming from 1990 acura integra
Jennifer what type of timing belt does your engine use ?
Is it Nylon ? When was the last time you had it changed ?
Burning plastic smell may be being caused by the timing belt bearing runners seizing and the belt is getting hot .
If the belt is due to snap you could cause a lot of damage to the engine if it breaks.
Might be worth getting a mechanics advice on this as a possible cause
Mar 04, 2017 | 1990 Acura Integra
DD603 was showing F1 error and motor was whirring away, put off an electrical burning smell then popped circuit breaker for kitchen. Now when turned on bottom drawer lights up, no life from top drawer then...
Hi mate - usually F1 codes on the dish drawers are leak related - its possible you had a leak and some components burnt as a result..
Control boards are located inside the door panels, the rotor in the mid of the washer are removed from the inside, I forgotten how to remove the cabinet drawer, only ever done 1 some 10yrs back - under the drawers are your heater elements and the motor stator (windings).
Its possible the motor have piked due to leaks - really have to dismantle it first before you can decide which way to go.
Sorry cannot offer more for now, copyright laws prevent me from showing you a cross section of the unit.
I will keep an eye on your progress...
Jun 24, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
No power.
check in back side u find 1 battery refix it.
If still facing problem then change battery .
Apr 11, 2009 | Dell Latitude C610 Notebook
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
When I start dryer makes a loud hollowing noice and smells burnt.
hi dcimproveman,most common noise on whirlpool/kenmore dryers are the rollers.i would describe that noise as a klunk,klunk.klunk.what you do is unplug unit,pop the top,take off the frount,loose belt and remove drum.takes me less than 5 min.clean inspect/oil /no wd-40 replace worn parts as needed.if you get stuck,just send an email
Jan 01, 2009 | Kenmore 62602 Electric Dryer
27 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
