Question about Iomega Computers & Internet
Iomega LPHD 400-U won't work
Won't work. computer doesn't recognize any longer. Never seemed to work properly from the start.
kamal1984
  • 1383 Answers
SOURCE: My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
Posted on May 22, 2009
  • 164 Answers
SOURCE: computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Posted on Jul 24, 2009
SOURCE: win 7 can't recognise my
Install the driver of the external hard drive first before connecting it to your computer, or when an icon appears on the lower right side of your desktop, right click on it and try to repair it by using troubleshoot compatibility. Maybe, your hard drive doesn't work with windows 7. You can run it in older versions of Operating Systems even if you have windows 7 in it.
Posted on Nov 19, 2010
bronk50
  • 27725 Answers
SOURCE: My iomega prestige 1TB hard
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
hope this helps
Posted on Aug 24, 2011
SOURCE: Manual for Iomega lphd-up
Try the manufacturer's website.
Get onlineand got to www.google.com In the google search box type: "IomegaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals throughout the site.
Posted on Jun 05, 2012
MATCHING CABLES FOR A IOMEGA LPHD-UPC
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Jan 24, 2013 | Iomega 500GB Prestige USB 2.0 Portable...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Iomega Portable hard disk service center in kerala
Look for the warranty center for Iomega, I did a quick google and found Accel the company to provide warranty. Look for their branches.
Nov 02, 2012 | Iomega Media Xporter Lphd up 160gb Usb 2.0...
MY IOMEGA LPHD-UP3 external/usb memory device, thinks it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps
Jun 27, 2012 | Iomega Computers & Internet
Iomega LPHD-UP 500GB power issue?
The fault sounds like a power supply problem. The USB port on your computer supplies up to a max. 500MA and this may not be sufficient for the external hard drive to work properly.
I suggest you get a new AC power adapter for this drive.
Apr 13, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
Driver for IOMEGA LPHD-UP
Please I need the Driver for iomega lphd-upc
Aug 07, 2011 | Iomega Computers & Internet
Computer doesn' t recognize iomega eGo portable
Jul 24, 2009 | Computers & Internet
Computers & Internet Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
