Question about McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
Repair manual manual fg 5700 ak 11 hp - McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
2 Suggested Answers
  • 122 Answers
SOURCE: model FG 5700 AK starts
there is a fuse or breacker that will trip some times so check that first, The wire may of came off from the plug in or the plug in will burn out some times or there is a diod in the motor they will go out you really need a meter to check these problems out just need to check the easy ones first fuse or bad wire good luck
Posted on Aug 04, 2011
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Where can I buy a mcculloch 5700 generator carburator
if you can not find a carburator you may need to find a re-built kit on the internet.
Aug 28, 2012 | McCulloch 11 HP 5700 WATT GENERATOR
I need a manual for my fg 6000mk 11 hp, 5700 watt, 5.70kva, 7097-fg6097
Hi Gary,
The manual can be downloaded from this link:
http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_FG6000MK-7096FG6024_966991401.pdf
You need to have Adobe reader installed on your computer.
You can get it on the Adobe website, www.adobe.com
Hope this helps!
Oct 17, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
What spark plug does a mc collough 5700 11 hp generator take?
The manuacturers part number is: 030506Q01F910
Manual:
Is there a brand.... on your current spark plug?
Most generators will do just fine with an NGK BPR5ES spark plug in most any environment.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
Model FG 5700 AK starts and runs but is not producing any power to the recepticles
Aug 04, 2011 | McCulloch Electrical Supplies
What type of oil do i use on the mcculloch fg 5700 ak
You may be using the generator in all temperatures so I recommend you use a SAE 5w30 100% synthetic oil in this air cooled engine. This will provide easy starting in extreme cold temperatures and great protection in all temperatures. Change the oil every 100 hours of use of every 2 years if you do not use the unit.
Jul 13, 2011 | Garden
FG 5700 AK generator starts and runs perfectly but has no output electricity. A meter across the 120 volt outlet reads 1.1 volts. I assume the rotor needs some residual magnetism to start the...
simple way to reflash the armature is plug a power drill into the genset, start genset, quickly turn the power drill by hand being careful to let go of it when it does turn on. this is a typical method for reflashing. good luck
Jun 21, 2017 | Electrical Supplies
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator Logo
41 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
