Question about Maytag MHW6000X Washer
Door locked and won't open - Maytag MHW6000X Washer
Problem with a 2005 Dodge Dakota
well it sounds like you knocked a rod loose that connects
to the door latch. now you would have to take off door panel and fix this issue from the inside good luck.
Jun 25, 2013 | Dodge Stratus Cars & Trucks
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
My back doors wont open
If your back doors won't open from the inside then the child proof locks maybe turned on. Open the door from the outside and look at the edge of the door near the lock for a small lever or screw setting for the child proof lock. Tun off the child proof lock and then you can open the back door from the inside.
May 09, 2012 | Dodge Cars & Trucks
Why wont the rear door open on my 2009 gmc acadia
from inside or outside ? if won't open from inside your child safety lock is probably tripped. if won't open from outside you probably have a lock rod that popped off inside the door, in which I would have the dealer fix it, it involves taking door pad off and when you can't open door to take pad off ,most of the time it damages it.
Mar 19, 2012 | 2009 GMC Acadia
Lock won`t open
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
Aug 13, 2008 | Frigidaire FEF352 Electric Kitchen Range
Maytag MHW6000X Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
