Question about Kenwood KNA-DV4100 GPS Receiver
Touchscreen isn't working with the GPS
I have the GPS receiver connected to my Kenwood DDX7015 monitor. When I start it up, it reads the cd but when it displays on the monitor I cannot touch the screen to chose the options. What can the problem be?
Press the v.set button more than once
Posted on Dec 19, 2007
SOURCE:
My nuvie 660 screen freezes, sometimes it works on startup, sometimes not. When it works on start up, it freezes as soon as I start to move
If you press the on/off power switch and can toggle the screen, then he unit isn't locked up at all. The touchscreen is either intermittent or has failed and needs to be replaced. More info can be found here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Apr 30, 2011 | Garmin Nuvi 660 GPS Receiver
I need a way to unlock a kenwood kdc 5018 radio i
i am pretty sure i had a kenwood that did that before. I think you have to hold 1 and 6 for 15 seconds or so . look for a default code from the factory in your book. thats the extent of my knowledge on that
Jun 07, 2009 | Kenwood DDX7015 RB DVD Receiver With 6.5"...
Kenwood ddx7015
i have a kenwood ddx7015, which is the best way to unlock it?
Jun 01, 2009 | Kenwood DDX7015 RB DVD Receiver With 6.5"...
Kenwood dnx5120 no detailed maps?
hi....
Open the cd/dvd tray and close it again. it should be a disc-read fault. That can be, the disc is dirty or damaged. Hope it's only dirty.
greetings and hope it will work soon, Gilbert.
Jan 19, 2009 | Kenwood DNX5120 DVD Navigation System GPS...
I have had my Kenwood DNX5120 for 2 weeks now, and yesterday the screen just went blank while driving. You can see the colors morphing around the buttons, but none of the buttons work. You can tap all over...
I just had this problem. You will need a pc with a dvd/cd writer. Go to www.garmin.com/kenwwood, and download to new firmware/software. Just follow the instructions and upgrade your 5120's software to version 2.60. All you have to do is unzip the file on your pc, copy it to your cd using your burner software, then load it into your kenwood's dvd/cd drive. Your maps should come back.
Dec 24, 2008 | Kenwood DNX5120 DVD Navigation System GPS...
Lost unlock code to kenwood ddx7015
There is a chip inside the radio. It can be replaced with another to clear out the code. It must be sent to the shop for this.
Dec 18, 2008 | Kenwood DDX7015 RB DVD Receiver With 6.5"...
Dubble den kenwood dvd player
There is a bulletin on the mech which requires 2 springs to be replaced. When you install disc the cd pushes on two sliders that push on switches to detect the position of the sliders the springs pull sliders back to original position. Sometimes the slider may stick due to not enough spring tension and possible restriction due to dust dirt etc. This would be a possible problem for your symptom . [email protected]
Feb 07, 2008 | Kenwood DDX7015 RB DVD Receiver With 6.5"...
Kenwood KNA-DV4100 GPS Receiver Logo
136 people viewed this question
Top Kenwood GPS Experts
Marvin
Marvin
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
