Question about Bulova Watch
Instructions quiksilver Venom - Bulova Watch
How to remove the band on the Invicta venom reserve
If you are talking about removing the entire band from the case, the Venom uses 2 spring-tension pins on each side, both of which must be released from their holes in the case to free the band. it is a tricky, hard to see procedure, even for a jeweler, but it can be done. I recommend taking the Venom to the jeweler the first time and letting them show you what the attachment looks like. This would make it easier for you to try yourself in the future without scratching the case or becoming too frustrated.
If you must try this yourself, be patient and use a small tool like a mini screwdriver to release the first pin via the small gap on the underside of the band, and then look for the 2nd pin which is further back. A small flashlight may help you see the pins. Then repeat on the opposite end of the band.
Putting the watch band back on the case is somewhat easier, still requiring patience and several tries. Don't lose or damage the pins.
Sep 29, 2015 | Invicta Watches
Invicta watch instructions
Straps are usually held in place by two spring loaded metal pins between the two lugs on either side of the strap. Look at the ends near the lugs you should be able to see them, use a very small flate blade srewdriver to pull back on the pin and once you get it, it will pop out of the hole its in.
Aug 18, 2014 | Invicta 15997 Mens Venom Chronograph Blue...
Could you help me with my roxy crushin krw222dr watch ? i cant set the time and date . please ?
Click on this link, to view the manual
http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf
May 13, 2014 | Watches
The manual of my quiksilver watch Chapter is not complete. what means AEL and KET?
KET means keytones
AEL means Light ON each time you push any key
Nov 14, 2012 | Watches
I would like to know how to reset my watch: quiksilver RANDOM M029 AL. Thank you
Try pressing all the buttons for at least 2 seconds. This might reset the watch like it does for other models.
Mar 01, 2011 | Watches
Where can i get a manual of my quicksilver traction watch?
I looked at the Quiksilver web site but could not find the model you have.
If you go to thier web site http://www.quiksilver.com/family/index.jsp?categoryId=2978686&sr=1&origkw=watches, you will see a list of watches and clicking on one of them will take you to a page that has "manuals" near the bottom.
Click on this and you will see a heading "analogue watches" but there are no instructions for digital types. If you watch is a digital watch, then I can only suggest that you contact them and ask them to send you a copy.
Feb 01, 2011 | Watches
I have an Invicta Venom #6111 with Poly strap. I want to put a Stainless steel ******** instead. How do I remove the caps covering the Screws holding the ********?
The caps are just for decoration. They dont cover anything. To remove the strap, you have to release the spring loaded pins from the underside of the band. There are two on both ends. Reuse the pins with the stainless band but be careful not to have a pin go into the wrong hole because they can't be removed without breaking them!
Oct 24, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
How do you remove links from the subaqua venom
Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
I dont want it to beep every hour. How do I make it stop
Go to the Quiksilver web site "www.quiksilver.com"
Enter "watches" into the "search " box.
Scroll down the page and you will come to the selection of manuals that you can download. Select yours and the method of turning off your alarm should be described.
Jan 02, 2010 | Watches
Bulova Watch Logo
61 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
