Question about Samsung LN46A650 46 in. LCD HDTV
IS THERE A JUMPER WIRE I CAN CUT LIKE ON OTHER SAMSUNG MODELS TO RID OF THE FLICKERINGflicker
2 Suggested Answers
  • 17115 Answers
SOURCE: How do I stop the flickering of my Samsung HD Smart TV screen?
http://www.shopjimmy.com/samsung-bn44-00612b-power-supply-unit.htm
Posted on Sep 17, 2015
Sep 16, 2015 | Samsung UN55F6300
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
I have a Samsung LN46A650 LCD TV and just recently I started getting an electrical popping sound while watching the TV. When this occurs, there are 2 light white bands across the screen and then it is...
without a standby error code or maintenance mode fault detection code, it's hard to say.
if you are looking for possibilities, then start with targeting the Ysus board as a possible culprit along with the Zboard buffers. the band would lead me to think buffers are having issues.
Nov 24, 2013 | Samsung LN46A650 46 in. LCD HDTV
SCREEN FLICKERING
The power supply module in this tv is part number BN44-00341A,
Samsung's dealer info says to:
For BN44-00341B; cut and remove jumper JP852.
This jumper wire is located just below the part number stamp on the pc board, I've done several of these and it cures the problem.
Jotvguy
Mar 04, 2013 | Samsung LN46C650 TV
Samsung picture flickers
Pull the back off the tv. Look at the power supply. Find jumper designated JP854 on power supply. Take a pair of wire snips and cut that jumper out of the circuit. Put the tv back together. That's it.
Jul 15, 2012 | Samsung LN55C630 TV
Lcd flutter ln-46c610
You might want to call Samsung with the model number as I remember seeing a notice for certain models that have this issue---a jumper plug needs in those sets to be removed that is located on the power board.
Apr 30, 2012 | Samsung LN46C610 LCD TV
I replaced the bulb in my Samsung HLP5674 wx xaa TV and now it turns off by itself intermittantly. How do I fix this?
You may have not gotten the lamp door switch positioned just right when you replaced the lamp door. It's been a common issue with Samsung in recent models. It's possible to defeat the switch by using a wire jumper across the switch plug and eliminate the problem all together if you're electronically apt.
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Samsung HCN473W 47" Rear Projection...
Just installed the honeywell thermostat. the ac turns on, but not the heat. what do we do?
Some of the thermostats from Honeywell require a jumper wire on the thermostat between the RC and the RH connection for the heating to operate. It is possible that your installation needs this jumper wire installed for the heating to work.Verify that this jumper wire is installed if your thermostat requires it. If it requires the jumper wire and you do not have one you can cut a small piece of existing wire on the connections to make a jumper wire. There are also some thermostats with a jumper switch for electric heat and gas heat...make sure that it is on the proper setting.
Dec 02, 2009 | Honeywell Electronic Programmable...
Samsung LN46A650 46 in. LCD HDTV Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
