Question about Vacuums
Beam sc375a, blown fuse on circuit board - Vacuums
Need location to buy replacement circuit boards or parts lists for circuit boards
many components can be sourced from shops like Jaycar or the like
try the manufacturer for a complete board or a schematic of the board
Dec 29, 2015 | Tenma 72-6340 Vacuum Desoldering Station
Dc15 fuse
Hi Lee,
I'm sorry to hear you're having difficulty with your DC15. If you'd like some help, please give us a call on 0800 298 0298 - we may be able to resolve the issue with some troubleshooting over the phone.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 05, 2012 | Dyson DC15 All Floors - The Ball Bagless...
On a Faema Due expresso machine: Viewing the circuit board from the component side, with the two 0.1 uf caps on the left. The two pins on the left of the eight pin connector are completely burned from the...
The descripion you have send is only for the board. We need to know also how is the machine.
Is the machine working good up today and you have descover this after a fault?
If there was a fault what was that?
We need some of this information in order to get the whole picture and history of the machine.
Jul 27, 2011 | Vacuums
System not working when switched on.Observed 3 amp fuse blown. Replaced with 13 amp fuse and switched to manual. Sparks and noise coming from one motor. ? brushes or motor need replacing.
Fuses blow for a reason. It's never a good idea to replace a fuse with a higher amp one. House fires can easily be started this way.
As for the motor, at this point the whole motor will need replaced.
Jan 15, 2011 | Beam Industries 2900 Serenity Plus Central...
System quit working green light on
depending on the year of your machine, assuming it is the serenity blue, it may be the circuit board on the unit itself. The manual switch "should" start the machine, but if not it will be the circuit board inside the main unit.
however....
if your unit is the green one, it may be the motor inside the unit and/or the circuit board. Hard to say. I do not think that it is the motor as the circuit breaker should have popped out if it was the motor.
Regardless of the colour of the unit, if it is 5-7 years old or less, the unit should still be under warranty. home service calls and labour to install the motor would not be covered.
Good luck.
Nov 19, 2010 | Beam Industries 2775 Serenity Plus Central...
Suddenly stopped running in the middle of vacuuming a room. Tried another outlet and still no power.
You have to go to the electrical panel that serves your home or apartment and locate the fuse that is blown [ if there are fuses, replace the blown one with a new one of the same amperage] or the circuit breaker which has kicked part way off. With a circuit breaker you have to turn it all the way off and then back on in order to reset it.
Aug 14, 2009 | Panasonic MC-V5481 Upright Vacuum
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Electrolux EL7020A Oxygen 3 dead!
There is a board in the back (called the "SUMO board") which has a fuse hardwired to it. Most of the "no go" problems with this machine are related to this.
In order to check it, you'll want to take a thin flat-head screwdriver, and gently pry up the silver panel on the top of the machine. The easiest place to do this is on the side of the panel, as far toward the rear of the machine as possible.
You will then need to remove the 2 Torx screws on the rear panel, and the top body of the machine should then be able to be removed. There are two clips in the bag chamber, directly under the back portion of the bag compartment lid, which can be pressed in to facilitate removal of the back cover.
The sumo board will be sitting directly on the top of the machine, and the fuse in question will be on the right if you are looking at it from the rear of the machine. Unfortunately, if the fuse is blown, you will have to replace the entire circuit board. (Unless you feel very comfortable with soldering a new fuse onto it, which I do not recommend for safety reasons.)
You can also check continuity of the cord reel from here. On the right hand side of the board are two spade terminals leading to wires running down into the cord reel assembly. One black, one white. Checking the continuity between these terminals and the ends of the power supply cord will allow you to determine if the cord reel is providing power to the machine.
Accessing the cord reel will require you to remove the six Torx screws holding the main body to the base. Two of these are on the rear of the machine, and are very deep inside; so you will require a very long-shanked Torx driver to get at these. Two more are inside the bag chamber at the rear, and the other two are on the front handle assembly. This will allow you to lift the main body away from the base, and if you are replacing the cord reel you can pull the wires from the spade terminals and the socket on the sumo board, and feed them back down into the cord reel chamber to remove the old cord reel.
Reassembly is simply a reverse of the previous. Beware, however: getting the cord reel to align is something of a chore, so make sure that you have the retraction system functioning before you put the whole thing back together, or you'll be bummed when you finish reassembly and the cord won't retract.
(I've definitely never done that. Nope. Never.)
Hope that helps, good luck.
-R
Jul 08, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
