Question about Panasonic HDC-SD80 Camcorder
Panasonic hd80 does not power on
Hello all, I rarely used my Panasonic HD80 Camcorder. But suddenly it stopped turnin on when the power button is pressed. I thought it could be a battery issue and I bought spare battery. But even after externally charged and fitted the battery the camcorder did not turn on. Unfortunately I could not locate the Factory ReSet button Any body have experienced this problem before? Any solution?
SOURCE: Camcorder won't record or playback
Panasonic NV-DS65 Ok, here goes, I had the exact same problem on my Panasonic NV-DS65. I've finally figured it out, I hope it helps on your cameras. Remove the bottom plate from the Camera (8 screws, 5 on the bottom plate, 2 on the side beside the hand grip(you will need to remove the grip), open the LCD screen and locate 1 screw below the ?still p-in-p button?. Then pop off the bottom plate of the camera Look at the ribbon cables carefully and gently push them all snugly into the plugs in case they are loose. The tape transport mechanism may have moved them out of place. Replace the cover and that?s it. Use a small screwdriver (one for repairing glasses is ideal) and do it over a table to prevent losing the screws. Also there are 2 sizes of screws so make sure you know what goes where. Thats it, hope it helps
Posted on Jan 19, 2007
  • 169 Answers
SOURCE: AG 460 panasonic camcorder" FUSE LOCATION"
just follow the battery and you will see the small fuse color white and have a mark of 3.15 at the bottom of the battery socket..
Posted on Aug 11, 2007
SOURCE: where is the reset button
I haven't used mine for over 2 years because of the mildew detected warning and not being able to find anyone to fix it for me. I just found this on the internet and am going to try it when my battery charges. Seems this is a common error for these palmcorders... good luck! "When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew."
Posted on Oct 08, 2007
SOURCE: how do i reset my Panasonic nv-gs70
It is on the Right hand side of the camera, just underneath the finger grip. Next to the Auto|Manual Fucus button... about 2 cm to the right.
Hope that helps
Posted on Jan 20, 2009
  • 5 Answers
SOURCE: panasonic dv camcorder keep havin
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time leaving the cassette inside and the battery attached.
Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
Push on the right place (marked "push") to close and then close the
cassette housing.
Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder for long period without being operated, and store the camcorder in a dust/humidity protected place.
Hope this can help.
Posted on Mar 12, 2009
How can I remove splotchy reds and yellows from HD80 picture?
it is possible the color wheel or sensor board issue.
at present, what you can do by yourself, please try to clean sensor board and that small black chip on it. perhaps it is helpful.
Aug 09, 2014 | Optoma HD80 Projector
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
An intermittent problem: When the "on" button on the control box is pushed, the light on the projector either turns blue and the projector powers on, or the light remains red and the projector...
How old is the lamp.
Have you changed anything in it recently.
Have you been using it regularly.
How old is the unit.
Are the lamp and filter covers on tightly
Apr 10, 2011 | Optoma HD80 Projector
I have a Optoma HD80 and the bulb has about 450 hours on it. I cleaned the projector, unpluged it for several mins and still turns off after starting. If the bulb has only 450 hours on it, why should I...
You have to check the bulb first. Its not the matter of how many hours you have used it. just check the lamp. may be it burned out. Its only a bulb it can burnout at any time. also check the lamp colling fan is working or not. if it is not working the same problem can occur.
Feb 06, 2011 | Optoma HD80 Projector
The lamp of my optoma hd80 shut down after 20 minutes. The lamp indicator problem light on. My lamp as only 880 hours. Do i have to change the lamp now?
Hi Pierre,
Did you resolve this issue. I am facing a similar on. After a few minutes, the lamp shut down and the the red lamp light turns on. I was thinking it is an overheating issue.
Mar 25, 2010 | Optoma HD80 Projector
Blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Dec 22, 2009 | Optoma HD80 Projector
My Optoma HD80 will not turn on.
if there is no standby light you are looking at a power supply issue
Aug 12, 2009 | Optoma HD80 Projector
Panasonic DVD Palmcorder (VDR-D100) 1.5 yrs old will not power up
Nope men... I have Just the same problem... I have a VDR-D105 and suddenly doesn't turn on... i was recording with a full charged battery and suddenly just turn off... forever :S
Jun 04, 2008 | Panasonic VDR-D100 DVD Camcorder
Panasonic HDC-SD80 Camcorder Logo
65 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
