How do you run self diagnostic on samsung front load washer WF218ANB/XAA01
  • 1294 Answers
SOURCE: washer won't drain
That is, in short: FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Posted on Mar 29, 2009
  • 58 Answers
SOURCE: Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Posted on May 05, 2009
  • 380 Answers
SOURCE: samsung washer wf218anb/xaa has code dc and wont
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Posted on Mar 10, 2010
SOURCE: WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Posted on Jun 13, 2010
Macmarkus
  • 2605 Answers
SOURCE: wont spin out sansung front load modle
Hello, Welcome To FixYa. Have you inspected the coin trap in the drain pump ? This applies to all SAMSUNG since 2008. Though the location varies from left to right hand side below the main door. The washers have a coin trap and manual drain. In the event you forgot to retrieve any small items such as coins prior to washing, the rubber hose inside the coin trap allows you to drain out the water allowing you to remove the trap for cleaning, but also to keep the inside as water-free as possible when not in use. ( which helps reduce odor build-up ). Let me know if this is something you've already attempted and we can go from there. Good luck and thank you for choosing FixYa. Regards, Macmarkus :)
Posted on Mar 27, 2011
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
Water leak at front left corner of our Samsung WF210ANW/XAA01 front load washer
You will need to order and replace the door seal, also verify the door is not loose due to worn hinges. Go to www.applienceparts.com for parts if you like.
Oct 26, 2016 | Samsung WF210ANW 3.5 cu. ft. front load...
Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Apr 26, 2012 | Samsung WF218ANB 4.0 Cu. Ft. Front-Load...
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND SPIN CYCLE, AND GIVES ME AND ND CODE
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 09, 2011 | Samsung WF218AN Front Load Washer
I Have a Samsung Washing machine model number WF218anb. I can't get it to go through the complete spin cycle. I have taken all the clothes out and put it on spin only and it stays on 9 minutes for a very...
Wow, I have the exact same problem. I reported it under my extended warranty, and the repair shop replaced the drum/bearings without fixing the problem.
I was looking at Consumer Reports today, and some of the people there reported the same thing. Interestingly, some also reported that Samsung told them they couldn't use this washer in places where the temperature got below 60 degrees because it's temperature sensitive, somehow.
But the overwhelming reports on this model are good. I got the whole sequence to run by putting it on perm press -- it spun OK!
Jan 31, 2011 | Samsung WF337AA Front Load Washer
Need to read owners manual for samsung wf218an washer
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
Aug 30, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
Samsung washer wf218anb/xaa has code dc and wont spin clothes they are still wet
Mar 03, 2010 | Samsung WF337AA Front Load Washer
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
