Question about Exercise & Fitness
Stairmaster 4000 pt
My steps are stuck at the top, and won't move! How do I fix this problem?
  • 914 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH My pedals on my Stairmaster are frozen in the top position, what do I check?
  1. Remove the alternator belt. IF pedals drop, problem is in alternator. IF NOT,
  2. Remove the drive chain, IF pedals drop, problem is in transmission, IF NOT,
  3. Problem is in hub assembly. Replace assembly.
Frozen Pedals in Top Position on Stairmaster Steppers
Posted on Sep 30, 2015
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Posted on Mar 14, 2010
  • 30 Answers
SOURCE: My Stairmaster 4000 PT pedals
have diode on the alternator checked , check all wiring connections to be tight, is the battery ok (6 volts ) and last check the motor control board for damage and/or electrical burn
Posted on Feb 03, 2011
My stairmaster will not rotate
Check the following video out for some troubleshooting steps regarding this issue.
Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net
Dec 19, 2013 | Stairmaster Stepmill 7000 Pt
Pedals stuck
Nov 28, 2013 | Stairmaster 4600PT Stepper
Stairmaster won't have a continuous workout
My Stairmaster unit seems to work in manual mode, but resets when I select a program. What is wrong? It is possible that the console on your Stairmaster unit may not be configured for the appropriate machine. This can result in the console accepting and allowing a manual workout but not accepting or allowing a program. Stairmaster Units Works in Manual Mode but Not in Program
Nov 01, 2012 | Stairmaster Exercise & Fitness
My stairmaster 4400 PT shows "config rqrd" How do
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Oct 14, 2011 | Stairmaster 4400 PT Stair Stepper
My Stairmaster 4000 PT pedals have no resistance. I have replace the brushes on the alternator. Any ideas ?
Jan 17, 2011 | Stairmaster 4400 PT Stair Stepper
I have problem with master console of step mill 7000 pt stair master
If you have a Stairmaster Stepmill 7000PT that has an older style console with the red LEDs and you want to upgrade to the newer, console with the blue LCD; the parts necessary for this upgrade include the console and the console cable.
Stairmaster Stepmill 7000PT Console Upgrade
C40 Console Repair Video for Stairmaster Steppers
Oct 19, 2010 | Stairmaster Stepmill 7000 Pt
Exercise & Fitness Logo
137 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
