Question about GE Spacemaker JVM1640SJ Microwave Oven
Jvm1430bd002 No Power at all.
    Top Expert:
  • GE Master
  • 12,223 Answers
Please make this steps , test it and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Posted on Nov 19, 2013
Noisy microwave on first Start... Not noisy on subsequent Starts
Does it sound like a fan blade rubbing?
Can you make a short video and upload it or share with me directly?
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 18, 2017 | GE Microwave Ovens
How many watts jvm1430bd002?
The GE JVM1430BD series of microwaves provide 950W of power. This information is in the Quick Specs for the microwave. The direct link to the document is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=340196_jvm1430bdwd_r2.pdf . (If the link changes, start here: http://www.geappliances.com/service_and_support/literature/ and search for your model. Three documents are currently available (Installation guide, Owner's Manual and Quick Specs) for the JVM1430BD series microwaves.
I hope this helps.
Jan 08, 2015 | GE JVM1430 Microwave Oven
I want to know how many watts my 2002 jvm1430bd002 microwave has...I have googled this question and have answers ranging from 700 to 1200! what gives???
Conduct what the USDA Food Safety and Inspection Service calls a "Time-to-Boil" test, which will help you estimate your microwave's wattage. Add 1 cup of water to a microwave-safe 2-cup measure. Add ice cubes and stir until the water is icy cold. Pour out the excess water, leaving just 1 cup. Place the measuring cup inside the microwave. Set the oven for four minutes on high. Watch through the glass to see when the water boils. If it takes less than two minutes, the microwave is 1,000 watts or more; if it takes 2.5 minutes, the oven has a rating of 800 watts or more; if it boils in 3 minutes, the estimated wattage is 650 to 700.
How to Find Microwave Oven Wattage eHow
Jan 08, 2015 | Microwave Ovens
I need to install my GE Spacemaker model # JVM1430BD002
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 16, 2011 | GE JVM1430 Microwave Oven
I have a GE Spacemaker microwave JVM1430BD002 There's a circular panel inside on the upper surface that's all greasy around the edges. It has arrows with 'open' close' on it but I can't get it to move. I'm...
That's the stirrer cover. It does need to removed and cleaned, and the stirrer parts above it, too. so that the grease will not eventually cause arcing and damage.
Your owner's manual should cover that. If you've misplaced yours, you can download GE owner's manuals and installation instructions here.
May 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
