Question about Motorsports
What causes my 2000 lincoln navigator to shake when driving 35 to 40 miles plus lose power
Shake and mis fire
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
Shake and miss-fire.....have you noticed any other symptoms? I would check spak plugs and hight tension leads for cross/miss fire firstly as this would be the most common cause. Once you are confident that these are not the problem you then have to open the can of worms. Most vehicles produced after 1990 are computer controled. This relies on sensors sending sending information to the computer so that it can deliver the correct spark or fuel mixture at the right time. If a sensor is sending the wrong info the computer sends a faulty adjustment which will cause a miss fire which will cause your vehicle to shake and lose power. The quickest way is to plug an analizer in to check the sensors. If that is not possible for you then more info is needed to give an educated guess at a correct diagnosis
Posted on Nov 19, 2013
My 2000 lincoln i changed the pcv valve and used rvt would that cause it not to start, I am still getting fire and fuel
Take it back out,and use nothing,is the hose going to the PVC good,check the other end of hose where it clamps into,mine went bad in my 2004 Lincoln ls 3.0.The hose was 50 bucks from Ebay,it broke off where it clamped to the intake,causing engine to have no power,if you shake PVC valve and it rattles,then it's good,it's a one way valve,the rvt may have clogged the PVC UP,I use nothing.
Aug 22, 2017 | Lincoln Cars & Trucks
2006 Lincoln Navigator shakes & no power
Could be coil packs they tend to weak and will misfire
Sep 11, 2017 | 2006 Lincoln Navigator
2004 Lincoln Navigator My steering wheel and air conditioner
If the air conditioner compressor is seizing it could cause the vibration you experience.
Jul 26, 2010 | 2004 Lincoln Navigator
My 2002 Mazda MPV recently developed an engine shake when stop at intersection or driving 45mph or slower. My mechanic scanned and found OS2 code, vacuum leak, replaced the intake hose, reset engine...
You might try another mechanic if this one can't get it fixed. Shaking is usually caused by one or more cylinders mis-firing for whatever reason--usually faulty ignition or fuel injection. Has the engine had recent tune-up? Bad spark plugs/plug wiring are frequent villains. Not sure what an 'OS2' code is. Hope this helps!
May 21, 2010 | 2003 Mazda MPV
I have a 2000 ford expedition. Out of the blue it started sputtering and shaking when I accelerate. Vehicle has144,000 miles.
Sounds like one of the coil over plugs have gone bad. this will cause mis-fire which causes your car to sputter, skip, and shake. It can be changed easily when finding out which one it is. But rather expensive for a simple part $40+ each.
Jan 02, 2010 | 2000 Ford Expedition
2003 navigator and right around 60mph i get a wicked shake or **** in the car. i think it may be a mis fire on the cylinder but not sure
Had the same problem, if it sputters/jerks around 50-60MPH with your foot slightly on the accelerator, replace all 8 COPs(Ignition coil over plug) and sparkplugs....It will get worst and end up ditching you!! NOTE: Make sure if you replace the sparkplugs, that the you or your mechanic works on the motor COLD and are very careful removing and replacing them. These 5.4L on 97-04 models are known for very little plug threading, therefore ejecting the plug out of the motor. This will result in major engine damage. Hopefully this helps
Jul 22, 2009 | 2003 Lincoln Navigator
At what millage should i change the automatic transmission fluid? The car is shaking when i put it in drive it dosnt shake when is in parking i need to put it in neutro everytime i stop in a light so it...
around 75,000 miles, plus or minus 15,000 or so. when you say shaking, do you mean a rough idle? thats not cause by your transmission per se...
Sounds more like a weak fuel pump, idle controller, or well, theres a bunch of reasons you could have a rough idle.
Jun 20, 2009 | 2002 Kia Rio
Engine shake 1997 chevrolet 1500 pickup
it sound like its mis-fireing new spark plugs
May 16, 2009 | 1996 Chevrolet Suburban
2000 IMPALA MISS FIRE AND BELT SQUEAL
have you changed oxygen sensors? also check wire and plug on #2 I changed plugs once and got multiple missfires changed 3 plugs to a different brand and it solved the problem
Apr 11, 2009 | 2000 Chevrolet Impala
Motorsports Logo
65 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
