Question about Garden
1992 polaris star lite gas in crankcase and muffler wont start
5 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: my 2002 polaris trailblazer wont start it has fire
If you have oil and gas and it will fire then try a new plug. A bad plug when removed will appear to be fine but under compression can fail.
Also try a splash of good gas in the throat of the carb or intake (if fuel injected) with a new spark plug. My bet is it fires just fine.
If this is a fuel injector type engine you could have a bad injector control unit or a clogged injector.
If it fires with gas in the intake manifold then suspect carb or injector system. (which ever applies)
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
  • 9 Answers
SOURCE: Hi there, I have a polaris 2003 scrambler 500. I
compression rings sound gone letting fuel into crankcase and filling up oil level, check compression and oil level
Posted on Sep 21, 2010
  • 8 Answers
SOURCE: I have a 1995 Polaris Magnum 425 4x4 4-stroke has
This is likely a carb problem. It's a common problem on Magnum engines. Check the main jet and the diaphram on top of the carb. Always turn the gas off on these when you're done riding. This way, if the carb is allowing fuel to drain in the oli tank, it won't drain the whole gas tank (which is what happened to you). This is not a piston ring problem with that much gas in the oil. good luck
Posted on Dec 10, 2010
  • 561 Answers
SOURCE: gas is coming from my crankcase on 1997 polaris xplorer 300 whats the problem
if this is the issue, suspect your fuel pump diafram is perished
also check if fuel is getting into your engine oil, check the dipstick and see
if the oil level is hight or its thin and runny oil smelling of gas,
if this is the case, recommend changing the fuel pump and changing the oil, in that order.
I hope this was useful.
Posted on Sep 02, 2012
Trailblazer 250 wont start
check/change, Battery, spark plug, remove air filter, use starter fluid, drain all old gas. use premium new gas. usecarb cleaner...should run,.
Mar 28, 2014 | Polaris ATV
Gas is coming from my crankcase on 1997 polaris xplorer 300 whats the problem
Sep 01, 2012 | Polaris ATV
Backfire problems
Check your timing
Aug 17, 2012 | Polaris ATV
Have mculloch fr 44 gas trimmer wont start check plug gas pulled apart carb wont start when trying to start gas comes out muffler
If there is a large excess of fuel in the crankcase it may well be the carb needle leaking, the only way to check this is with a bulb pressure tester connected to the fuel inlet nipple, it should hold a pressure here if the needle is not leaking, if you cannot get a pressure then the needle is leaking, it can be replaced, it will have a rubber tip, also make sure on the metering side of the carb the gasket goes on first followed by the diaphram and cover, the gasket acts as a spacer.
Aug 24, 2011 | McCulloch Garden
98 400 scrambler where do you drain the crankcase oil and wheres the oil tank
i just got a 2001 polaris 500 and the oil tank is under the gas tank behide the rad cant miss
Mar 21, 2011 | Polaris ATV
2001 polaris sportsman 90 is this a 2 stroke or 4 stroke
It's a two stroke, it has a separate spot to put the two cycle oil under the seat. It injects the oil itself, so you just make sure its always has two cycle oil in there and fill the gas tank with straight gas.
Dec 24, 2010 | Polaris ATV
I have a 1995 Polaris Magnum 425 4x4 4-stroke has gas in the oil after starting it. It was sitting since January. The oil tank and crankcase were filled with gas. It also comes out the pull starter hole.
Jun 28, 2010 | Polaris ATV
Does a polaris 400 sport need engine oil
no engine oil in the crankcase on a 2 stroke it mixxes with the gas you do have counterbalancer oil in the dipstick below the carb and tranny fluid in the transmission
Apr 02, 2010 | Polaris ATV
Homelite Mighty Lite won't run but a few seconds
Check your muffler to be sure doesn't have a build up of carbon from the oil/gas fuel. This is the problem with 99% of equipment that uses mixed gas. Take the muffler off and see if it runs better without it. If so there is carbon build up in the muffler and muffler port on the engine. Burn the muffler in an open fire for a while to remove the carbon, or burn it with a torch, toss out the screen that's is in most mufflers, (unless of course you live in California where they are required), Scrape out the port with a knife and after the muffler cools on it's own (don't cool with water as you will warp it and not get a good seal) reinstall and see if this solves the problem.
Jun 24, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
