Miele Error Codes F53 - Washing Machines
3 Suggested Answers
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
SOURCE: How do I fix a F53 fault ona Miele W1712 Washing
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
Posted on Oct 27, 2012
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
Nov 02, 2017 | Miele Washing Machines
How do I fix F53
This is a speed sensor fault. Could be caused either by the motor itself (built-in speed sensor) or by an electronic fault.
What is most likely depends on your model. See Miele goedkoop repareren cheap repair preiswerte Reparature
Mar 03, 2015 | Miele Washing Machines
How do you retrieve codes for 1996 F53 without a scan tool
some fords are under the dash by the steering wheel and others are under the hood close to the fuse box by the wheel well.
May 09, 2014 | 1990 Acura Legend
I have fault of f53 what does this mean
Hi, Below is a post by a previous fault to you washer, I hope this helps you. taurustech
  • Rank: Guru miele.gif
  • Rating: 92%, 159 Votes
i,
All the credit goes to taurustech
Jul 15, 2011 | Washing Machines
What the meaning of f53 ptoblem?
Error code F53 on Miele is a speed sensor fault.
It has detected the drum speed to be wrong at some point and has indicated the problem to you.
Have you tried unplugging it. That will reset the computer.
If it's not coming up again after unplugging it, I'd not worry about it.
If it is coming up every time you use it, then you have either a faulty sensor, motor or pcb.
Miele are extremely secretive with information on their appliances and this makes it hard to diagnose accurately faults on them.
May 16, 2011 | Miele Novotronic W1930 Top Load Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
May 21, 2010 | Miele W865 Front Load Washer
F53 code coming on while on the wash cycle
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 21, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
