Question about Samsung UN55ES6100FXZA
No back light led strip burnt
Power supply ok but one of the led strips is burnt no part# i need the part#
3 Suggested Answers
SOURCE: I have a Samsung 3yo LED TV and it just stopped working. No standby light. I took the back cover off to see if the power supply board had any issues but can't see anything burnt. Help!
Did you check the plug top connections or fuse?
Posted on Apr 02, 2016
gopakumarg43
  • 74251 Answers
SOURCE: Samsung un39fh5000 shutdown no led start has info on screen usung a flashlight replaced both main and power supply bds chked led strips no burning visiable ohms reads high no short im stumped
T'Con board fault. With most modern models of Samsung LCD sets, this board is a built in part of the display panel. If it is a separate part (in case of your set); replace it. Check it out.
If it is a built in part with the display panel, there is no repair other than replacing the display panel.
Posted on Aug 26, 2016
Samsung tv MODEL UN40F6300AFXZA
Please un-plug the cable between the main board & the power supply board, apply AC power to the TV, if the back light come on, that means the back lights & the power supply are OK, then you need to replace the main board; if the back lights does not light up, mostly the back light LED strip(s) is bad.
May 24, 2017 | Samsung Televison & Video
Tip
TV led back-light repair
Tv using power supply unit EAY62810301.
No back-light/sound ok.
No dc voltage measured at P801 led plug.
New board did not fix.
Remove display panel.
With face up, panel will hinge up. (after removing all trim parts) Place folded towels beneath, to prevent strain on tcon ribbon.
Fold other screens up and over on top of display to keep them in right order. Including white background reflector.
Check each series led string with 2*9V batteries and series resistor, minding marked polarity.
Circuit consists of 3 strips of 7 leds all in series.
One bad led disables all .
Check each led of bad string. I used 18V and 1K ohm.
Replace strip or jumper (short) bad led. I just jumpered the bad one that was on edge of panel. (first in string).
http://i.fixya.net25611904-d2havjugub54lsdvnfsaynwf-2-0.jpg
on Mar 28, 2015 | LG 32LN530B 32" 720p LED-LCD TV - 16:9 -...
Hisense 50k22dg should i replace led strips first or power board
I would inspect the power board for mushroomed caps and brunt traces. A edge lit led screen has two ribbon cables coming from the power supply, I would unplug one at a time to see if one side lights up. Both led strips rarely go bad at the small time. The problem is most likely in the power supply.
May 02, 2017 | Hisense Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
I have purchased a power supply led board and a main board board for my Samsung Tv and that didn't help. The light flicker on then go back off
Did you replace the LED light strips? You have a bad connection on the LED light strips or one LED itself is going bad.
Feb 01, 2017 | Samsung Televison & Video
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
LG 32LN5300 LED TV that suddenly went to Black Screen no sound. Should I change out all three strips of LEDs?
This sounds more like a power supply problem than a problem with the backlighting, plus the lack of sound also would indicate something other than problems with the backlighting.
Oct 02, 2016 | LG 32LN5300 32" LED TV 1920x1080, 60 Hz,...
Power board and back lights led tv
BL Inverter board fault. It's not working [oscillating]. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jun 27, 2016 | Samsung UN32EH5300FXZA 32 in. HDTV
I have a 50" element tv. Model # ELEFT502 The picture went black but sound still works. when u take a flashlight to it u can still see the picture. Easy fix??? Also where/how much would the part be?!
http://electro-medical.blogspot.com/
Jan 11, 2016 | Element Televison & Video
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Samsung UN55ES6100FXZA Logo
51 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
