Question about Dewalt 18v Battery Hammer Drill Dcd950 Dc925
I have a dewalt DCD950 it does not have a chuck retaining screw. I want to change the chuck
I tried the allen wrench and channel locks to remove it It does not come loose.
5 Suggested Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
  • 178 Answers
SOURCE: remove c keyless chuck from 18v dewalt drill
There is no loctite on the chuck threads, only blue loctite on the reverse screw. This is how I remove chucks.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Posted on Nov 26, 2010
  • 885 Answers
SOURCE: Hi i took the screw out of chuck put allen wrench
The chuck is put on extremely tight even the ones with a set screw. You have to hit the allen wrench HARD, almost to the point to where you think you may break it. I have also had good results using an air hammer with an allen socket. Just make sure you're turning it in the opposite direction the screw turned coming out.
Posted on Dec 23, 2010
  • 304 Answers
SOURCE: How to get the chuck off a dcd950 dewalt hammer drill
Only the screw in the centre of the chuck would be l/h tread, the chuck should be normal thread and come off in an anti clockwise direction. Please confirm drill model number.They did a version where you needed a service tool to remove it and refit. It is torqued on.
Posted on Nov 22, 2012
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
How do you remove the chuck from a dewalt 12 volt dw953 drill
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it.
Apr 12, 2011 | Garden
Can't get the chuck off my DCD950
if trying to remove the keyless chuck/open chuck and down inside is a hex screw useing a hex wrench place long end in screw and give the wrench a sharp rap with a hammer to break loose/....(not sure if dewalt has left or right hand threads)and i have had to rap a drill with a rag and place in vice to help hold it.......hope it helps
Dec 30, 2010 | Dewalt 18 Volt Compact Drill Kit
How to take woodchuck off
If you mean how to take the chuck off, here you go. Open the chuck jaws all the way. There is a screw at the bottom of the chuck going into the shaft of the drill. If I remember correctly, it is a combination flat, or t30. This screw is reverse thread. Remove it by turning it clockwise. Once the retaining screw is out, get a 3/8 inch allen wrench. tighten the short end into the drill chuck. Lay the drill down on a work bench so that the long part of the allen wrench is hanging off the edge, facing you. The chuck comes off regular thread, so you are going to rotate the allen wrench counter clockwise. They are usually pretty tight. The best way is to put the drill in low range, and hit the allen wrench with a hammer so as to turn the drill chuck counter clockwise. Install the new chuck in reverse order.
Nov 21, 2010 | Dewalt 18 Volt Compact Drill Kit
Remove c keyless chuck from 18v dewalt drill
Jun 15, 2010 | Dewalt 18v Battery Hammer Drill Dcd950...
How do you remove a key chuck from a dewalt drill
first shift the drill to the drill only position and the gear selector to the low position, remove the chuck retaining screw LH thread, find a bent handle allen wrench about the chuck capacity and lock in the jaws of the chuck, put the chuck on a block of wood at about a 30 degree angle to hit the long portion counter clockwise and strike it with a hammer, it might take a couple hits but it will come off. I misread the header last time.
Oct 01, 2009 | Dewalt Drills
Can't remove the chuck retaining screw.
Place drill in vice with chuck in vice facing up . Clamp chuck lightly but with enough force to hold firmly.
put allen wrench in chuck and lightly tap down to make good fit to allen screw head.Clamp chuck jaws down onto allen wrench lightly to hold wrench steady. Take piece of pipe to end of wrench,10".
These chuck screws are tight. Hammer clockwise until screw brakes loose.Open chuck completely and remove screw.Chuck is threaded to spindle shaft . Place allen wrench with long end facing out of tool in chuck and tighten chuck securely. With hammer tap allen wrench sharply counter clockwise ( normal thread.)
Jul 08, 2009 | Makita Drills
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Nov 24, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck replacement
Hi Paul with the screw out you will have to lock the short end off a sturdy allen key in the jaws off the chuck then sellect first gear on the drill then with a hammer hit the long side off the allen key so that the chuck unscrews normal thread (anti clockwise) the shock off the hit will free the chuck.
Hope this helps.
Sean.
Apr 02, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18v Battery Hammer Drill Dcd950 Dc925 Logo
83 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
