Question about Samsung Galaxy Tab Tablet PC
Battery will not charge
Device doesn't recognize usb connected to port and will not power up to charge
  • mary
    mary Nov 25, 2013
    :) I'm new to the forum. So I'm probably repeating myself.
    Thanks for your reply, Kent. The USB and wall charger (Samsung) was not the issue, although charging from a power strip may have been. I understand from readings online that low voltage output (< 2.5, laptop or third-party adapter)is a common problem resulting in failed software power management.
    Anyway, Samsung CRM is very good and walked me through a diagnostic and power cycling.
    GIVEN: OEM USB cord and wall adapter
    SYMPTOMS: dark screen or intermittent battery charge indicator; tablet does not respond to "hard reset" (HOLD PWR + VOL button 10 sec. RELEASE PWR, hold VOL 10 sec.) which launches SYSTEM RECOVERY MENU; battery completely discharged, insufficient power ON or OFF.
    ACTION:
    1. Disconnect USB power supply. Wait 60 sec.
    2. Re-connect USB cord, plug wall adapter in wall socket for 1 hour (approx. 20% charge up)
    3. Disconnect USB power supply. "Hard reset."
    4. SYSTEM RECOVERY MENU display: Press the Volume Up or Down button to select "wipe data/factory reset", and then press the Power button to make your selection.
    Press the Volume Up or Down button to select "Yes - delete all user data" (Factory Settings), and then press the Power button to make your selection.
    When the reset is complete, press the volume Up or Down button to select "reboot system now", and then press the Power button to make your selection.
    5. Power OFF tablet.
    6. Re-connect USB cord and supply. Charge 3 - 4 hours.
    Tablet turned on promptly at 100% charge. Over the next couple of days, repeat Steps 5,6 when battery indicator is no less than 15%. This cycling re-sets software baseline (min. operating level).
  • 3 Answers
Silly question but have you tried a different charger maybe the plug is worn hopefully not on the tab
Posted on Nov 23, 2013
Won't reload on my ipad
Connect to wall outlet Uses the USB power adapter and USB cable included with the device. If it is a third-party accessory, check to see if it is Apple Certified . Then follow these steps:
  1. Connect the iPhone, iPad or iPod touch to the Lightning to USB connector cable or the 30-pin to USB connector cable .
  2. Connect it to one of three power sources:
Wall outlet
Connect the charging cable to a USB AC adapter and connect the USB AC adapter to the wall outlet.
Computer
Connect the charging cable to a USB 2.0 or 3.0 port on a computer that is not in sleep mode. Do not use the USB ports on the keyboard.
Power supply
Connect the cable to a powered USB hub, docking station, or other Apple-certified accessory.
When the device is charging, you will see a lightning bolt next to the battery icon in the status bar or a large battery icon on the lock screen.
Aug 12, 2017 | Tablets & eReaders
Tip
Kindle not charging
If your Kindle (any version) is not charging because the USB port has gotten loose, try this...wrap a small piece of aluminum foil around your USB connector - the end that plugs into the device. Be careful not to extend the foil past the end of the connector, you don't want to damage your device. Plug the cable in to the outlet and into the Kindle port as usual, then watch the orange light come on!
Kindle charging ports get worn out over time, the foil is a great conductor and makes a solid connection. Obviously, you'll want to try a different cable first, but if that doesn't work, this is free and easy!
on Mar 26, 2015 | Amazon Kindle Fire HD
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Why won't my 10.1 tablet charge?
Hello Pauline,
I know this must be frustrating. When this occurs, it is more times then not a problem with the hardware power port on the tablet. (the hole you plug the USB cable into on the tablet)/ The USB cable cannot make a solid connection because the port is damaged, and therefore electricity cannot get to the device or battery.
Do you have a warranty? I recommend seeing if the manufacturer will replace it. Also, if you have device insurance, you can try and get a replacement. Either way, you must replace the broken hardware power port.
May 25, 2015 | Hannspree HannsPad SN10T1
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
What do ido to make my kindleD00901 operational SCRREN showing critical battery
The nice thing is, that the Kindle/Amazon charger (Ac adapter) is clearly marked as being an Amazon/Kindle charger.
So, here's what you do, perform the hard reset of the Kindle (slide and hold the power switch over to 20+seconds; count slowly; release, then connect to your Amazon/Kindle AC adapter. Then leave it connected for 30+minutes; and should the battery charge, the Kindle screen will return to normal.
Alternate step to try is; if you don't have the actual Kindle AC adapter, you will need to try to charge via the USB port from your computer.
The trick here is, that the Kindle takes longer to charge direct from a computer USB port, and the computer has to be left on the whole time and CANNOT go to sleep, as the power to the USB ports might be turned off.
Also, it's best if you connect to a "powered" USB hub, or the USB ports found at the back of a computer tower (not the front USB ports as most of the time, the front ports do not supply enough power for Kindle charging).
May 25, 2014 | Amazon Kindle 3G
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
Kindle will not charge from out let or computer
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Jan 01, 2011 | Amazon Kindle 3G
"USB Device Not Recognized" - any usb device
It May just be a hardware problem... try putting in some new usb ports.
Dec 14, 2008 | HP Pavilion tx2120US Tablet PC
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
Samsung Galaxy Tab Tablet PC Logo
64 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
