Question about Toshiba TEC B-SX4 Thermal Label Printer
How do I turn the rotary cutter on and off our toshiba SX4 thermal printer running windows
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
You can juste select the option in teh windows driver.
Select batch printing and no cutter when you don't want to cut.
Posted on Jun 10, 2014
4 Suggested Answers
  • 254 Answers
SOURCE: TOSHIBA B SX4 thermal barcode printer and Solaris 10
First of all change the escape caracters used to define the tpcl commands.
(2) parameter
code auto to {|}
Substitute in your code ESC ={ Lf = | and Nul =]
The printer will ignore the other control caracters
Posted on Sep 02, 2009
  • 254 Answers
SOURCE: Hi, I have a brand new SX4 with a rotary cutter.
Your problem is related to the size of your Tags.
When the label is fed to be cut, the notch is placed on the sensor. Since there is no paper the value recorded says no paper. Try to recalibrate the sensors or stick a piece of liner on the sensor.
Posted on Aug 05, 2011
  • 254 Answers
SOURCE: barcode printer type: TOSHIBA SX4 sensor
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
How to change from Thermal Transfer to Thermal Direct on Toshiba TEC-SX4
Hi Ryan, refer to sections 5.2 Overview and 5.3.1 Printing Mode Selection from the following pdf manual. Hope this helps.
http://www.cmsitechnologies.com/TEC%20Drivers/BSX45TUM.pdf
May 20, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Ribbon error problem for Toshiba TEC B-SX4 Thermal Label Printer
Calibate the detection value and check the rbbon motors values
a sammler ribbon could need some adjustments
Mar 27, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Tec sx4 network
Have you checked the port Number.
Tec use port number 8000 and the standard default in windows 9100. Either you change on your printer or in the driver.
Feb 12, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a brand new SX4 with a rotary cutter. I am printing 2 types of tickets, one with a black mark and one with a notch cut out of the side (gap). The problem I am having is that when printing the...
Feb 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
System error showing on my toshiba tech sx4
Hi Thanks for your question.
First thing you should try is unplugging your printer from mains and plugging back again after 30 sec or so. Good Luck
May 10, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Download a new firmware.
- check that the antiparasite cores are mounted on the ribbon motor cables
Mar 16, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Need a Strandware (not Windows) driver for a TEC
bartender ultra light + driver or use a tecb472 driver (same resolution same language
Feb 24, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I can print to a TEC B-SX4 from a windows 2000 print server, but if I set the printer up on a windows 2003 server it goes offline and refuses to print. Same drivers Seagull 7.1.1.
this is due to continuous polling by the driver.
You must disable the bidirectional communication in the tools tag ,driver options, network parameters.
May 11, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
(2) parameter
code auto to {|}
May 07, 2008 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
63 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
