Question about GE GSS22JF Side by Side Refrigerator
Interior light bulb glows orange and makes noise Whirlpool side by side refrigerator
Bulb glows orange and make noise
4 Suggested Answers
SOURCE: Heating element in a refrigerator?
The orange glow you see is your defrost heater. Your refrigerator goes into the automatic defrost mode three times a day. This keeps the unit frost-free.
Posted on Oct 02, 2007
  • 29 Answers
SOURCE: The appliance interior lights works but it's not cooling or freezing
The compresser could fail yes, but you could also have an open circuit. If the contacts in the thermostat got corroded, or the starter relay, it may simply not be told to turn on. It may be time for a technician to measure continuity in the circuit.
Posted on Jan 28, 2008
freetek
  • 5568 Answers
SOURCE: GE Side by Side Refrigerator Not Cooling but Freezer is working
This is a good indication of a failed fan.
The freezer compartment gets first crack at the compressed coolant and a fan distributes some cooled air to the refrigerator side. When the fan fails, the fridge suffers.
Sears parts department has thousands of illustrated breakdowns of many appliances and if yours is one of them, you can see the location of the fan for DIY purposes and often how to access it.
They also have (for listed appliances) the mfr.'s part number and the failed part can often be ordered right from the page on which it is displayed.
Sears Parts Direct
If you can ferret out the part number, you might check listings in your area for Johnstone Supply which supplies trades people with a huge variety of replacement parts and the prices are often 40-60 under dealer prices for the same items and have never turned me away as a non-professional DIY person.
Posted on Jul 13, 2010
Whirlpool Side by Side refrigerator interior refrigeration section light glows orange and makes noise
Have you tried replacing the lamp to see if problem goes, is so then its probably coming from the door switch.
Nov 18, 2013 | Whirlpool Refrigerators
Light bulbs are flashing with constant pulsing noise
It sounds like you have a lose connection for the lighting. It may be at the light bulb socket or even at the door switch. It also could be a lose wire going to or from these items. with a little detective work you should be able the bad connection.
I hope this helps :)
Apr 21, 2010 | Whirlpool GD5SHAX Side by Side...
Ref light bulbs and noise no cooling wh-pool GS5SHA
I had the same problem. There is a main controller board at the bottm of the refrigerator near the back by the compressor motor. One of the components on the board shorted out and the board had to be replaced. Total cost about $150.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light flickers in refrigerator
Yor refrigerator has a control board in 2 places. I would like to to unplug and pull the refrigerator away from the wall. Behind the cover where the compressor is located there is a circuit board. Take the cover off and examine the board for burn marks and loose solder connection. Let me know what you find. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Light not working!
you sure is not the door switch making noise when open
Mar 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Whirlpool Side By Side GD5RHAXNQ00-Electrical Issue
The arcing noise is just that, a loose connection causing electricity to arc from one place to another. this is initiated by opening the door and closing the light switch. The small glow is from a small amount of voltage reaching the bulb. If you are inclined, repair it. remove the cover, look for the burnt wire or connection. If its a removable part, replace it. If not clean it up and/or make a new connection. One thing is for sure, it will not get any better and may get worse and burn up something more critical.
Jan 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Oct 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS22JF Side by Side Refrigerator Logo
11 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
