Question about Sharp MX-M260 Digital Copier INCLUDES DOCUMENT FEEDER
Sharp mx-m260 stuck in copy mode
The machine is stuck in the copy mode. it copies fine. it will not go into print or fax mode.
checkitright
  • 1362 Answers
SOURCE: the fax will not print anything
2 possibilities
1- you did not remove the plastic film on the cartridge
2- the printhead has dried up
Posted on Dec 06, 2007
checkitright
  • 1362 Answers
SOURCE: Need User manual for a Sharp UX-175 Fax and copy machine
BAM !!! here you go
http://www.usersmanualguide.com/sharp/faxes/ux-108_178_188
Posted on Dec 10, 2007
  • 82 Answers
SOURCE: SHARP UX 105 Fax machine ....Problem
is this making a screeching, high ptch sound. If so that is normal when sending. as far as the rest yes that is normal.
Thank You,
Mikey
Posted on Apr 03, 2008
thedayos
  • 57 Answers
SOURCE: Black vertical lines on the sent copies.
Sandmanmac is correct. There HAS to be a scanner element in ALL fax machines - If not, you may as well fax a blank piece of paper. The recipient will be expecting one as well. A tiny speck of dirt will cause a line for as long as it remains there - A dab of rubbing alcohol or glass cleaner on a cloth and cleaning the scan part eliminates the line - To test it - try the "Copy" mode. The same scan part is used to make copies with your fax machine. Just make sure you "keep it clean"!
Len
Posted on Apr 15, 2009
FixinFax
  • 3085 Answers
SOURCE: Black line down page when faxed or copying
Open up the document feeder and clean the scanner glass
Posted on Mar 27, 2010
What is the solution to error code f2 sharp mx-b200
oem cartridge not third party
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 05, 2014 | Sharp Mx-b200d Digital Multifunction Copy,...
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Sharp MX-M260 Copier Machne
Check if you have the right driver, it could also be that you don't have a scan function and need to pay for it.
For drivers check:
http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=MXM260&cat=341
Dec 10, 2013 | Office Equipment & Supplies
Copy machine is stuck in the copy mode
Sounds like the machine does not have a fax board on it. Have you been able to fax in the past?
If nothing else, try rebooting the machine, then have your servicing dealer come out to check the fax board module if rebooting doesnt help.
Skelton Business Equipment Houston Copiers
Nov 18, 2013 | Sharp Mx-m260 26ppm Copier
Copies have a line through them.
First, clean the slit glass under the lid. There is a thin glass area on either the right or the left side of the large glass that probably has some gunk on it. give it a good spit shine and that should get rid of the line. If not, you probably need a new drum/cleaning blade combo.
How To Remove Lines from copies prints on Sharp copier
Oct 23, 2013 | Sharp MX-M260 Copiers/scanners
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
I just received a new sharp mx-m260 copier and now need the mx-mm9 fax function. How hard is it to install the fax function
which model do you have. you have listed two different models in you post mx2300 is color MX260 is b/w.
Anyway the mm9 is a memory module for fax not a fax kit. The fax kit is a Fxx7 I think
May 24, 2010 | Sharp MX-2300N Color Copier
Sharp UX-B750 won't automatically answer calls.
Your reception mode is set to TEL/FAX or TEL mode, to set it to automatically receive faxes it should be set to FAX. Look at the LCD display ( right section ).
To change the reception mode you can print the HELP LIST by pressing COPY/HELP button.
May 26, 2009 | Sharp UX-B750 Inkjet Fax
Sharp fax printing problem
Curfman.....your scanner has gone bad
kireeti....open the document feeder and check for obstructions or a switch actuator stuck down.
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp MX-M260 Digital Copier INCLUDES DOCUMENT FEEDER Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
