Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
I got a LFD 12314 ariston diswasher. After 5 minutes in Normal appears A11 on the screen. Please help me. Rod
I have the code AL01 on my diswasher ARISTON HOTPOINT , how to resolve teh problem ??
AL01 is the error code for flooded base.
Firstly, disconnect the power cable!
Check the trumpet pipe that goes from the pump to the heater.
Is there water in the base, if so you need to remove the water and dry the base. Hope this helps and good luck.
May 01, 2018 | Hotpoint Washing Machines
Electrolux 24 in. Diswasher
Hello Darlene, thank you for allowing me to assist you!
The "ER" code that keeps appearing on your Electrolux dishwasher stands for a Membrane Switch Failure. Normally that means that your control board has detected a stuck key or key pressed for more than a minute. That could possibly be an issue with your keypad or main control board. I would recommend having a technician come out to your home to properly diagnose and repair your dishwasher. I hope this is helpful. -Matt
Aug 02, 2014 | Electrolux EIDW5905JS Dishwasher
We have an ariston pro pi water heater and water is dripping all over from the bottom. How do you drain this? It is less thasn 5 years old
The tank is drained by removing tank, and using hot water outlet as a drain.
Under-counter tanks are not made with thick steel hull that adds cost and weight to product.
Water heater can rust out quickly if anode rod is not checked and replaced each year.
Anode rod depletion is faster if home has water softener.
All tank-type water heaters have replaceable anode rod that protects tank from rusting, and most water heater manuals include general description of anode and maintenance.
http://waterheatertimer.org/Replace-anode-rod.html#ariston
Rusted water heater must be replaced.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Bosch GL4Ti Ariston Pro Ti Electric...
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
4) Information on anode rods
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
I have an LSv66 Ariston dishwasher. When it is switched on, no matter what program, the knob just stays in the same position. It sounds as if the dump pump is running constantly.
The dishwasher overflow detection may have triggered. This causes the drain pump to operate.
The overflow float is located at the base of the diswasher and maybe faulty. It is spring loaded float and should move down and up when pressed. If you cannot find this in your model, then water has leaked into the overflow cavity where the motors are located. This could also trigger the overflow protection circuit.
You have to replace the overflow float if it exists or empty the overflow water in the overflow cavity and dry it out. If leak is taking place then the gasket needs replacement.
Hope you are able to fix the problem with some of the suggestions I have made.
Please rate the solution if you find it helpful otherwise post a comment.
Oct 11, 2010 | Ariston Technologies LL64WNA Built-in...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
155 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
