Question about GE Dishwashers
GE Evolution GSD4128 - Top part of wash tower fell off
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Posted on Jul 01, 2009
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
Problem with wash tower of GE GSD2200G00ww not rising up
if the tower isn't rising DURING the wash cycle it is most likely caused by one of 2 issues. 1 being too low of a water level which can be caused by low flow thru the pipes, blocked filter in the inlet valve, or a bad inlet valve. The 2nd cause can be low pump pressure due to the main food shredder screen, located below the large plastic "filter" in the rear right-hand corner, being plugged with garbage. The valve can be replaced if needed, the filter can be cleaned w/o removal of the entire unit, but if the water flow is low, you will most likely need a plumber.
Nov 22, 2012 | GE Nautilus 24" Built-in Dishwasher
MGE Evolution UPS 1550 Tower How long is the warranty on this unit?
Eaton Powerware now handles the MGE Evolution product. Standard warranty is 2 years warranty, Standard product exchange, including the battery(return to depot or the seller).
Eaton Powerware should send out a new unit via courier at their cost, if you call the 1-800 number and give them the serial number and describe the problem. You ship the UPS that is not working to them in the box they send out the replacement UPS and they should include a collect waybill to ship it back to them.
Mar 07, 2011 | MGE Evolution 1550 1440VA Tower UPS...
How to remove a rising wash tower
Grasp the largest segment of the tower and turn it counter-clockwise while holding the lower wash arm.
Jun 15, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
GE WDSR2080D5WW will not spin.
One of them support rods is probably broken
Apr 01, 2010 | GE WDSR2080D Top Load Washer
The spay tower in the bottom fell out. should
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
Dec 21, 2009 | Kenmore Dishwashers
Jul 01, 2009 | GE Kitchen Ranges
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Spray tower fell off
The Spray tower fits in the bottom rack, Its actually pretty obvious as there is no way it can sit int he position it has to without being in the rack itself otherwise the rack and tower would block each other all the time.
 Examine the base of your spray tower it should have two "clips" or plastic protusions that will, with a circular twist, snap onto the bars of the middle of the rack itself. Then when in place and your rack is slid inside the dishwasher the tower should sit directly over top of the exact middle of your bottom spray arm.
et Voila.
Nov 09, 2007 | Kenmore 24 in. 16309 Built-in Dishwasher
Dishwashers Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
