Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Fax problem My 440-cn would not pick up a dial tone, receive a fax or send a fax. When I press hook button, there is a click but not tone and another click when hook button is pressed again. Caller ID no more works. I have a VOIP network with vonage. I used to have a VOIP with another network. My fax worked perfectly then over the VOIP using my single phone number. This problem started since I changed. The current phone line is connected from VOIP modem to line in phone port on 440-cn and then another line from ext phone port on 440-cn to external phone. Phone works perfectly but fax machine itself would not pick up dial tone. Dial tone detection on fax machine is on. Off position does not make a difference. I have tried using fax only mode, TAD and manual modes without success. I don't have a distictive ringing service. I obtained seperate dedicated fax line from line 2 port of VOIP modem without any change in problem. Called brother, said if machine cannot pick up dial tone then connection from modem to machine is the problem. Makes sense, but external phone works perfectly. When I obtained dedicated line, there is a dial tone when I connect a phone directly to the VOIP modem or through the phone ports (line in and ext phone ports)of the machine. Vonage swears that their fax service works like normal phone line and should be received by any fax machine. What do I do next.
  • 4,889 Answers
If the wall jack has a dial tone, disconnect the telephone line from the telephone and connect it to the jack on the FAX/MFC labeled LINE. Make sure the line cord is connected from the jack on the FAX/MFC labeled LINE directly to the wall jack. Press the Hook or Speaker Phone key or pick up the external telephone handset and listen for a dial tone.If there is still no dial tone, your machine may require service.
Click the link below to spot the nearest service center....
http://www.brother.ca/en/customer_care/service_centers.asp
Posted on Oct 11, 2007
  • eagle338
    eagle338 Oct 11, 2007
    Please let me know if it has worked...
    Sergeant:
  • 279 Answers
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Posted on Oct 08, 2007
  • John Goodman Oct 10, 2007
    Did you check on any of what I wrote before rating my answer - and if so could you please give me that information? I can't help you further without it.
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How ican send a fax with samsung scx-4521f?
hello
first you connect the telephone port to your machine and telephoe line.
.then load your fax document to ADF. then their is a button in your machine its name ON HOOK DIAL .press it then you can here some dial tone. press fax number if you wont to send. then you can here some ringing tone and press start button after fax tone coming.
Jan 12, 2011 | Samsung SCX 4521F All-In-One Laser Printer
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Help when i try to fax using my brothers 560, the number dials, the machine sounds like it's faxing, but the disply says telphone. how can i correctthis
Do you pick up the hand set when you are dialing, If you do the display will read telephone. When you want to send a fax put the paper in the document feeder. Dial the # press the start key or put the documents in the document feeder press the hook button to here the dial tone, dial the number what for the tones pres the start key. hope this helps
C.W.H.
Jan 29, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
668 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
