Question about Averatec 3200 Notebook
Black LCD Hey I got a use averatec 3200 with a cracked lcd screen I replaced the screen with a use lcd, turned it on was working ok for 3 days how it turns on with a black screen, I checked the 3 corrnection ok is it just a bad screen of something else.
  • Anonymous Oct 24, 2008
    averatec 3200
    Is there a special name for the back light, what is the part called?Hhow hard is it to fix? Can I fix it myself? How much $? How do you take the back cover off?
  • 661 Answers
Sounds like you have a bad backlight, the backlight shines light through the translucent LCD layers to give you your picture in the same way you hold slides up to the light
Posted on Oct 09, 2007
My averatec laptop will only power on to a black screen but it still sounds like its booting
1) Laptop on use a flashlight, and shine it at the LCD screen. Shine at various angles.
Do you see faint images?
2) You can also plug in a VGA monitor to the back of the laptop, (Laptop OFF, monitor off), and toggle over.
(It can be a VGA monitor that looks like a small TV {CRT}, or an LCD flat screen that has a VGA cable attached)
Plug the VGA monitor's cable into the blue VGA port on the left side, of the Avertec 3200 Notebook PC.
(Example of VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Turn the VGA monitor on. Give it time to 'come to life'.
Turn the laptop on.
Are there graphics on the external monitor? If not press, and hold down on the Fn key, (Blue Fn next to the CTRL key), then tap the F2 key.
(The F2 key is the toggle over key for an external monitor. You can use the laptops LCD screen, or it's screen, and an external monitor)
Graphics show on the external monitor? Your graphics chip is good.
Problem is with the screen Inverter, or the Backlight.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and the Backlight.
90 percent of the time the fault is the screen Inverter.
The Display Assembly essentially is;
1) Top cover of the laptop. (Display Cover)
2) LCD screen
3) Display Bezel. (Thin plastic frame in front of the LCD screen, and surrounds the LCD screen)
4) Inverter
5) Backlight
6) LCD screen frame
With the Display Bezel removed, the screen Inverter should be at the bottom/front.
This is an example of a screen Inverter for an Averatec 3200 from a quick search,
http://www.laptopaid.com/averatec-3200-lcd-inverter-board-76-030105-02-tested-1629.html
I haven't worked on an Averatec 3200 Notebook PC before. I have worked on 100's of other laptops.
The sequence for removing the Display Bezel follows a pretty standard approach.
Looking at the Display Bezel I see four screw covers. (I'm looking at a PDF Users Guide)
One at the top Right corner, one at the top Left corner, one at the bottom Left corner, and one at the bottom Right corner.
These screw covers made of a rubber-like material. (Synthetic rubber) They are slightly rounded on the top. They have a type of rubber cement that holds them in place.
I use a computer pick to gently pry them off. If you carefully pry each screw cover off, and set them down sticky side up, (Screw side), you can usually reuse them again.
Screw covers (4) removed, use a Philips head screwdriver, and remove all 4 screws.
The Display Bezel will still be held in place. It has plastic tabs on the outside edges that snap into the Display Cover. (Top cover of laptop)
A fingertip is used on the INSIDE edge of the Display Bezel, next to the LCD screen.
(WATCH your fingernails against the LCD screen)
The fingertip raises the Middle/Inside edge of the Display Bezel, just slightly.
Now use another fingertip on the opposite side. Raise the Middle/Inside edge.
The Display bezel should start 'popping' out. (As the plastic tabs release they make a popping, or snapping sound)
To illustrate this technique further,
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-latitude-e5400-e5500-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
(One more, to show you where I believe the screen Inverter is for the Averatec 3200 Notebook PC, and what an average screen Inverter circuit board looks like,
http://www.insidemylaptop.com/remove-screen-inverter-dell-studio-1737-1735-laptops/
When the Display Bezel is loose, you slide it to one side a little to ease it around, and off, of the cover latch.
The cable connectors going to the screen Inverter are shaped differently from each other, so that when you go to reinstall them, there is no chance of mixing them up.
With the tools you have available, I would replace the screen Inverter ($7 plus shipping), and see if this repairs the problem.
If not the problem is the Backlight. Most of the time you have to buy the LCD screen, as the Backlight is an integral part of it, and should be replaced by a professional.
[ An LCD screen is composed of layers. The layers are held together in the correct alignment by the LCD screen frame.
This alignment MUST be aligned as it was from the factory.
This gives you an example of replacing a Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Make a mistake here, and you can throw your LCD screen in the trash ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 21, 2011 | Averatec 3200 Notebook
Good Day..my nokia 3200 has a problem with its LCD there are two black lines appears on the screen..as the days goes by the lines getting better..i need some help on how to fix this problem..
Experiencing black lines or forming stain is not repairable anymore,possibly needs a replacement,if the parts is with your,this can be change simply by removing the front covert and unscrewing 6 screws using T6 precision screw driver or anything that can release the screw.gently lift up the entire frame to separate the main board,now lift up the lcd connector on upper right portion using any flat thing like cutter or something.now you can replace the lcd and test if the replacement works fine.
Otherwise,bring the phone to a service center for LCD parts replacement.
Thank you for visiting FixYa....
Aug 12, 2011 | Nokia 3200
Screen has crack and I live in Scotland near Glasgow
Most Notebook LCD screens are available online. Try looking for the product or part number of your LCD screen and search it on google and you should be able to find where you can get a replacement for that. ^_^
Jun 06, 2010 | Averatec 3200 Notebook
I have an averatech 3200 laptop and the screen would be dark when reaching a certain point before loading to windows. I hooked up to a monitor and on Device Manager it says there is a problem with the...
the inverter board below lcd panel will be faulty(inside lcd casing) try replace that it will solve the problem
in case if it is led-lcd then led-lcd panel will be faulty then replace whole panel ###www.aris.in####
May 26, 2010 | Averatec 3200 Notebook
Screen wont light up.
Try testing the system on with an external monitor if it displays then the screen LCD is faulty and need to be replace with a new one.then the best thing is to get the screen been change .
rate this solution..
May 07, 2010 | Averatec 3200 Notebook
I repaired the female power jack in my Averatec and must have compromised something else in the process as now my screen has two large black quarter sized black spots, on quarter of the screen at upper...
If you put any pressure on the screen while repairing the power jack then yes, the LCD will need to be replaced. If you are certain that you did not physically damage the screen during the repair then it is possible that you damaged the motherboard (which houses the video processor). If the motherboard was damaged I would say it's time for a new laptop.
Aug 24, 2009 | Averatec 3200 Notebook
Want to replace Averatec 3200 Laptop Screen
Do you know for sure the LCD screen and not the video card is faulty?
You may find it cheaper to repair the LCD screen than replacing it.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 16, 2009 | Averatec 3200 Notebook
Black Screen
The first thing I would do after turning the computer on is check to see if the video output is being directed to the LCD screen. The output can be directed using the Fn key along with the key with the picture of the 2 monitors on the Function keys at the top of the keyboard. Hold down the Fn key and tap the other key once or twice,
Next, hook the computer up to an external monitor. Do the same thing with the Fn key to see if it's the LCD screen.
If the external monitor works, then you haven't correctly hooked up the LCD screen or it's bad.
Feb 05, 2009 | Averatec 3200 Notebook
How do I replace the screen on my averatec 3200?
I visit a site frequently calle www.instructables.com. It's an amazing site that shows common people how to do simple and complex things. I found a DIY on how to replace a notebook's LCD screen
http://www.instructables.com/id/DIY---Replace-Broken-Laptop-LCD/
I also found a couple of prices for your the LCD screen. The first one is an ebay auction that actually gives you instructions, too. What's good about this one is that it gives you it specifically for your notebook.
http://cgi.ebay.com/NEW-AVERATEC-3200-12.1%22-XGA-LAPTOP-LCD-SCREEN_W0QQitemZ180238139440QQcmdZViewItem?IMSfp=TL0804301363a9095
http://www.screentekinc.com/Averatec_3200_Series_AV3220H1--12.1-inch--1024x768-xga-laptop-lcd-screen.shtml
http://www.excelcomputerinc.com/html/details.asp?ref=929&category=inverter
I hope this helps,
-Ernest
May 02, 2008 | Computers & Internet
1/3 screen is blank and loose power jack
The LCD needs to be replaced. As for the D/C Jack its the sort of laptop an engineer would have to play by ear. Or in otherwords work it out as they go along. Try removing all of the screws that you can find and be careful that you know where the screws go back afterwards. You might need to flick the hinge covers off to access the rest of the laptop. They also tend to have plastic clips all around them.
Aug 28, 2007 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
108 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
