Question about Whirlpool MH1150XM Convection/Microwave Oven
Whirlpool microwave model mh1150xmb
The light bulb on the underside that would light up the range cook top burned out. I replaced the bulb as I have done dozens of times and it still does not turn on. I tested the bulb to verify that it was good and it was so, I then inspected the lamp holder and it appears to be in good shape. The button (switch)on the control panel that operates the light does make a beep when you press it (it always has) to turn on the light; is there a way to test this switch without dismantling the micro-wave? Or is there a known condition of the switch since it does make a tone when pressed?
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
Please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
whirlpool microwave model mh1150xmb - cac2fea3-4ef0-49a3-b17b-698c60318973.gif
Posted on Nov 19, 2013
4 Suggested Answers
SOURCE: Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Posted on Nov 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I replaced the bulbs in the underside of the
prototech@usa.net
Posted on Jun 02, 2009
I have a whirlpool combination microwave with oven. How do I change the bulb in the microwave?
Whirlpool Microwave Bulb Replacment - YouTube
? 4:35
https://www.youtube.com/watch?v=RQM302PShKw
Oct 29, 2011 - Uploaded by Dan Jiles
I show how to access the bulb on a Whirlpool Microwave that shines on your cook top, as well as how to access and replacethe bulb that is for the microwave ... ... How to disassemblemicrowave oven. Find info: fuse, bulb, fan ..
Nov 07, 2015 | Whirlpool Microwave Ovens
How do I change light bulb under a 2009 ge microwave/model no.lvm1750dm1ww
The range top bulbs can be replaced by removing the screw that holds the glass and frame to the underside of the unit, they swing down, the bulbs usually screw in, the power needs to be turned off by way of unplugging the unit before replacing the bulbs, the interior cavity bulb can be replaced by removing the top grille and accessing the socket assy from the front. Pleazer Appliance...
Dec 22, 2014 | GE Microwave Ovens
MH1150XMB
It's important that high-current devices like microwaves be on their own dedicated breaker.
I would suspect the 20A fuse and then the oven cavity thermostats, in that order.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (such as the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Oct 11, 2012 | Whirlpool GH8155XJ Microwave Oven
Model #mh1150xmb-0 The light bulb under the microwave burnt out (with a bang) this morning. Although the lights and clock come on the microwave it won't start.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too, and on these models, can prevent them from starting or running.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
Dec 18, 2010 | Whirlpool MH6150XL Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
May 06, 2010 | Maytag Over-the-Range Microwave
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
prototech@usa.net
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Nov 12, 2008 | Whirlpool MH1150XM Convection/Microwave...
MH1140XMS Oven Stays On
Right, but I wondered if you might want the OLD broken board fixed, too, as a backup? Keep it in mind, It's only $39.95.
Feb 07, 2008 | Whirlpool MH1140XMS Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
126 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
