Question about Ranco J10-821 Horizontal Wallmount Humidistat w/ 20-80% Relative Humidity Range
Humidistat wiring diagram
I have had a ranco humidistrat installed on air feed plenum to gasfired furnace. It worked fine last year. I changed the filter and nozzle this year and it won't start working. Could the solenoid go bad?I haven' touched any wires from humiddistat to furnace to solenoid. We have had warm weather here but could that be the cause of humidistat not starting up? Thanks
Why dose drum spin when furnace is not on?
Usually the unit is mounted to the cold air return (cold or intake air) and the round hose is then attached to the plenum (hot or discharge air). The humidistat is usually mounted just above the unit onto the meta plenum, unless you have a control somewhere else or your main t/stat has that capability built in. Its usually wired in with the furnace 24Vac control (or whatever yours happens to be) so that the unit only comes only when the furnace is on.
Dec 08, 2014 | Honeywell HE120A Whole House Humidifier
I have a aprilaire 700 I just installed on return plenum. Have a problem with the wiring, the instruction say to connect the R&C wires from humidistat to the same on furnace power strip. Is the C
Depending on the age of your furnace you may have an aux terminal for a humidifier. If not, you should use the white wire (heat) coming from the homes thermostat to power up the humidistat and ultimately bring on the humidifier. This way it will only run when in heating mode.
Nov 16, 2012 | Aprilaire 700 Humidifier
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
I installed a honeywell 360a flow thru humidifier, and a new transformer. I have power thru the wires to the fan cover. Also the humditstat clicks when turned on. The fan does not work and the solenoid...
Posting a diagram of how you wired the installation will help the both of us figure out what the problem is. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 11, 2011 | Honeywell HE360A1027 Whole House...
I'm a 35 yr home builder in northern Ohio. I built a new house for myself two years ago and had my HVAC contractor install a trane system, he nat gas furnace, a/c, electronic air filter and trane...
It's supplier responsibility to make the unit right. are you controlling your dehumidifier with remote, If so, remove battery in remote and reset it. And then check. If still problem, please get manuals fro the following site and do accordingly
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Dec 15, 2010 | Heating & Cooling
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Valve makes a loud clicking noise and activates over and over again
Sounds like your humidistat is the problem. Try turning it off, if still clicking, disconnect one of the wires at the valve (if accessable). If the valve doesn't close, replace valve. Otherwise replace humidistrat.
Nov 27, 2009 | Honeywell Humidifiers
HE220A1019 Whole House Humidifier
The humidifier is designed to "pull" the air through the water panel. After it does the humidified air will re-enter the plenum on the side of the opening that it is pulling in from. Just keep the water panel replaced every year and you will be fine.
Jan 26, 2009 | Humidifiers
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Ranco J10-821 Horizontal Wallmount Humidistat w/ 20-80% Relative Humidity Range Logo
54 people viewed this question
Top Ranco Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ranco Measuring Tool and Sensor Expert? Answer questions, earn points and help others
