Washingmachine leaks water
Water leaks from bottom of the Kenmore front load washer Model # 79641472210
  • 57 Answers
SOURCE: GE front loading washer leaking
With only a limited amount of information, I would guess your door seal may be worn....but how can you check it? Take a reqular piece of paper (8.5x11) and cut a strip 1x11. Open the door and while holding onto the paper strip, put the strip in the TOP of the door and shut it to see how the seal 'feels' when you try to pull the paper out. It should be very hard, if not impossible to pull the strip of paper out. Now, do the same thing with the bottom of the door. Does it appear to be much easier? Without knowing the age of the machine, I might question the door seal. You might also want to check to see if the door might not be bent just a bit. Do this by placeing a long level vertically along the front facing with the door open, then check the door for level. It may be as simple as bending the top of the door out while you bend the lower part in.
Good Luck
Posted on Feb 23, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 714 Answers
SOURCE: kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Posted on Feb 28, 2010
SOURCE: kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
Posted on Jun 01, 2010
Testimonial: "good to go "
Kenmore front load washer is leaking water from soap
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
My front load kenmore washer door gasket is garbelled
Something probably got caught in the seal and pulled it out of place. If u run washer so that it fills up and starts tumbling,,, and there is no water leak,, there is a good chance u can repair this yourself. So if there is no water leaking,,, you can try and take out the bottom front panel and twisting, or shoving it back into place. If there is water leaking,,, than chances are its ripped or broken, and will need to be completely replaced
Mar 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Kenmore f l washingmachine 110.46472501 leak from dispenser
This is joyce
is dispenser in properly, remove and put back in. sometimes the peice that is seperating the solid from liquid is in the way and causes water to come out top.
also water pressure has a lot to do with this. has this changed. have you removed filter?
thanks
joyce
Feb 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
