Question about Huawei Ascend GSM Unlocked Android 4.1 Phone Y300 BLK
How to increase volume
The speaker volume is too soft even though it's on full volume
Having trouble with the volume even though its on full I can hardly here the caller thanking you
What kind of phone is it. Chances are the speaker dock is coming unplugged or faulty. If it's an iPhone it's super easy to change and fix.
Nov 06, 2016 | Cell Phones
How to increase speaker volume
There is a volume button on the phone to increase(up arrow) and to decrease(down arrow). Keep pressing the up arrow to increase the volume till you can hear clearly either with speaker or without speaker.
Sep 13, 2014 | Lands Phones
Soft sound
Well it sounds like the speaker is not working properly so it's the speaker that's doing this not the console it's self then. 2 double AA batteries I use energizer and duracell for mine and do not use re chargerAble batteries either
May 09, 2012 | Nintendo Game Boy Color Console
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
How to increase volume in vastro 1014 i am not getting full sound though the sound is 100% even in vlc sound is low if i see the volume while playing i think only half of the volume is coming how to go in...
Right-click your speaker icon and open playback devices
Select speaker and click Properties
Click the Levels Tab and you can adjuat the levels from there.
May 26, 2010 | Dell Vostro 1014 Laptop Computer
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Volume problem
try reducing the output volume from the pc, maybe to about half or even a quarter of full volume. now increase the volume on speakers.
Mar 21, 2010 | Logitech X-540 Computer Speakers
Low Volume from headphone jack...
I do not think that this TV does not have a separate circuitry with its volume control for the earphone. If your earphone is mono, are you using a plug that is mono to connect the speaker?
Try using AWG 20 if you could to see if that helps.
Good Luck.
Jul 24, 2008 | Durabrand DWT2405 24" TV
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Huawei Ascend GSM Unlocked Android 4.1 Phone Y300 BLK Logo
306 people viewed this question
Top Huawei Cameras Experts
sandrasteven
JonSnell Electronic
JonSnell Electronic
Tony Parsons
Tony Parsons
Are you a Huawei Camera Expert? Answer questions, earn points and help others
