Question about Seagate U5 (ST320413A) 20 GB Hard Drive
32 GB hard drive limitation
I can't get my Seagate 250 GB Hard Drive to detect or install any more than 32 GB
  • 4,889 Answers
WinXP & Win2k cannot create FAT32 partitions larger than 32 GB.IF you want to use partitions larger than 32GB in WinXp then you will need to install a third party partition tool like Partition magic. Partition magic is probably the best coz i have formatted my 200GB HDD in 2 mins flat!
Posted on Oct 08, 2007
SOURCE:
Dell b110 does not recognize more than 32 gb of hdd
check the jumper settings of the hard drive
The drive is larger than 32GB, but the operating system only recognizes 32GB. If the operating system, BIOS or DiscWizard can only recognize 32 GB of the drive it may be caused by one of the following:
  1. Drive Jumpers: Applies to Mac and Window users. On drives that are larger than 32 GB there is a Capacity Limitation Jumper (CLJ), also known as the Limit Capacity Jumper or the Alternate Capacity (AC) Jumper setting. This jumper will limit the capacity of the drive to 32 GB and should only be used when the BIOS hangs when trying to auto-detect the drive. If you have two jumpers shunts on the drive you will need to remove the CLJ or AC jumper. If you format the drive with the CLJ or AC jumper then the drive capacity will be limited to 32GB. After removing the CLJ or AC jumper the drive will still be recognized as 32GB. You must reformat the drive without the CLJ or AC jumper to gain the full capacity of the drive. The other option is to create a second partition with the remaining unallocated disc space.
  2. BIOS: On older systems (pre- November 1998) the BIOS may not support drives that are larger than 32 GB. In the BIOS setup please set the drive type to AUTO detect. If the BIOS detects the full capacity of the drive then the BIOS will support the capacity of the drive. If not please perform one of the following:
    1. Check with the system or motherboard manufacturer for any BIOS upgrades for the system.
    2. (Recommended) Purchase a PCI ATA controller card that will support the capacity of the drive. The two benefits of ATA controller cards are:
      • The ability to support large capacity drives
      • The ability to support the faster transfer rates of the drive.
  3. Operating System: Windows have a 32 GB format limitation for FAT 32. That means if you formatted the drive in FAT 32 with Windows, the largest partition supported is 32 GB. You will need to format the drive in NTFS if you want to partition the drive larger than 32 GB. The other option is to create a second partition with the remaining unallocated disc space.
  4. Incorrect Reporting to the BIOS: The drive itself may be reporting the incorrect size to the BIOS. In order to correct this, you will need to download SeaTools for DOS, boot into the SeaTools disc, and run the Set Capacity utility. It is recommended that you only have the hard drive reporting the incorrect capacity connected to your system while performing the following steps. Any other hard drives should be disconnected.
    It is recommended that you back up any important data on the hard drive before using SeaTools to set the drive size. This is a potentially data destructive procedure. Seagate is not responsible for any lost data.
    After correcting the drive capacity, the drive may still show a partition size of 32GB but with unallocated space. You must delete its current partition then repartition and format the drive to gain the full capacity of the drive. The other option is to create a second partition with the remaining unallocated disc space.
    1. Insert the SeaTools for DOS CD or floppy disc into the appropriate drive, and restart your computer. When SeaTools boots up, carefully read the license agreement, and press Y if you accept it.
    2. Select the correct drive from the list using the mouse or keyboard.
    3. Choose Advanced Features .
    4. Choose Set Capacity to Max Native.
    5. Once the capacity has been set SeaTools has returned to the main screen, take the SeaTools disc out of the drive and completely power down the system. The system needs to be shut down so any cached information is cleared. If you simply reboot or reset your computer without completely powering it down first, the corrected capacity setting will not take effect.
REFERENCE TO THIRD PARTIES AND THIRD PARTY WEB SITES. Seagate references third parties and third party products as an informational service only, it is not an endorsement or recommendation - implied or otherwise - of any of the listed companies. Seagate makes no warranty - implied or otherwise - regarding the performance or reliability of these companies or products. Each company listed is independent from Seagate and is not under the control of Seagate; therefore, Seagate accepts no responsibility for and disclaims any liability from the actions or products of the listed companies. You should make your own independent evaluation before conducting business with any company. To obtain product specifications and warranty information, please contact the respective vendor directly. There are links in this document that will permit you to connect to third-party web sites over which Seagate has no control. These links are provided for your convenience only and your use of them is at your own risk. Seagate makes no representations whatsoever about the content of any of these web sites. Seagate does not endorse or accept any responsibility for the content, or use, of any such web sites.
Apr 14, 2014 | Dell Dimension™ B110 PC Desktop
How to reformat 250gb seagate freeagent hardrive which can't be detected in my computer and disk management?
make sure the connector of the hard drive is in good condition,if the connector is good ,then the hard drive is crashed
May 24, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
Seagate hard drive model st320014a be external but not readable in the window 7
Hi
Uninstall the Seagate Hard drive in the device manager and reboot your computer. By this case, let windows detect it.
I believe you are using Windows 7 64 bit which is causing problem.
If not solve, Just install Windows 7 32 bit and sure it will works.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 13, 2011 | Seagate (ST320014A) (st320014a-25tpk) 20...
Recently i purchase a new 250gb external HDD it's coming into ntfs format by default... now i want to format into fat32, so that i can use both of my pc windows and mac.... (mac is not supportable ntfs...
DEAR A FAT32 SYSTEM SUPPORTS A MAX VOLUME SIZE OF 32 GB PER PARTITION SO MUST DIVIDE IT INTO THAT LIMIT I THINK YOU SHOULD HAVE UNDER STOOD. ANY VOLUME MORE THAN 32 GB (VOLUME = SPACE) IN NOT SUPPORTED UNDER THIS SYSTEM
Feb 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Why my portable seagate 250gb free agent go cannot detected
what OS you are using??
try to check the cable connector of the hard drive..
Sep 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My portable hard disk is not detecting by my PC/Laptop. it's working on other PC/Laptop. and i also installed my hard disk drivers.it also giving beep sounds.
The power supplied by the pc laptop on the USB is insufficient to run the hard drive.
If you have an external power supply option on the hard drive, please use that.
Sep 06, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows vista on Vaio laptop does not detect new Seagate FreeAgent Go 250 USB 2.0 GB drive.
try formatting your laptop again with vista O.S. but dont install anti virus after installing it because there might be some conflict with the anti virus you installed with the O.S.
Jun 27, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Windows 2000 advanced Server does not support Seagate 250 GB Hard Drive.
I am inclined to think that this would be a problem with the jumper settings limiting the size of the drive.
I can't offer anything more than that, sorry. Hope it will help a bit.
Aug 08, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
Seagate U5 (ST320413A) 20 GB Hard Drive Logo
185 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
