Question about Tanaka Garden
Cuts out when opening thoutle
Carb rebuild kit
olwork
  • 237 Answers
SOURCE: 84 s10 carb
Any auto parts store can get the kit for you. The carb should have a metal service tag attached to one of the screws on top or side. You'll need the numbers on this tag to get the correct carb kit. If no tag is found then look for numbers either stamped or cast into carb, probably on bowl or on top.
Posted on Jun 28, 2009
mattofilms
  • 110 Answers
SOURCE: need a rebuild kit for int updraft carb
this is a type 6 part.
Means = no longer avalible.
you will have to get from wreakers
Posted on Jul 02, 2009
  • 151 Answers
SOURCE: How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Posted on Dec 27, 2009
  • 430 Answers
SOURCE: I can't seem to find carb. float adjustment info
The bottom of the float should be level/ parallel with the bottom surface of the carb.
Posted on Dec 30, 2009
SOURCE: Can't find a carb rebuild kit for my 1983 Honda VT500FT Ascot
Bike Bandit has everything you need to rebuild the carburetor on your 1983 Honda VT500FT V-Twin Ascot, click on the link below to view
http://www.bikebandit.com/houseofmotorcycles/1983-honda-motorcycle-vt500c-shadow/o/m9690
Posted on Apr 18, 2010
Will start, runs for a minute or two then cuts out
Carb probably blocked. Carb must be cleaned off the blower! Pull it and get the make and model off of it to get a rebuild kit for it online. Look up rebuild video online and watch it prior to attempting rebuild/cleaning. A can of carb cleaner and a couple basic hand tools is all you need to do this!
Good luck and be careful!
Sep 22, 2013 | Garden
Bike starts and idles but if you take the choke off it cuts off
sounds like the pilot jets are clogged,need to clean/rebuild carb,(carb kit).
Mar 05, 2011 | 1994 Yamaha XV 535 Virago DX
2005 vulcan 800 will only run with choke on cuts out when you give it gas
the pilot(idle) jet is clogged,need to do a good carb clean/rebuild(carb kit).that should take care of your problem.hope that helps.
Feb 21, 2011 | 2005 kawasaki VN 800 Vulcan Classic
My brush trimmer starts ok. I try to accelerate out of idle and it immediately cuts out. I have owned this unit for 3-4 yrs and this is the first problem I have encountered. Thanks in advance for any help!
I had a 32cc that did the same thing. I had to install a carburetor rebuild kit to cure it. You may be able to get away with just installing the diaghram kit or can opt for the full rebuild kit (includes all parts in the diaghram kit). This usually remedies this probem, but not always as there are other items that need maintenance or replacing periodically...like the fuel filter, the fuel lines (when they go bad, they clog up the carb).. and air filter. If you rebuild the carb, clean it only with non-flammable brake cleaner spray as other carb cleaners have too harsh solvents in them and can damage sensitive internal parts like check valves in the carb. Don't blow it out with high PSI air either as you can damage check valves that way also. Post back if need be.
Aug 14, 2010 | Craftsman 25cc Gas Line Trimmer
How do I set fuel screws on carb of saw 55 model chainsaw starting is difficult, will not run, cuts off whenn it does start. suspect carb settings altered.
A better suspect is the fuel pump. It is a diaphram in the carb that converts the vacuum pulses into pumping the fuel. This is a common problem when saws are a few years old.
Get a carb rebuild kit complete with the little flapper check valves. The fuel, especially with the alcohol added destroy these diaphrams after fuel sits in them a while.
Jun 20, 2010 | Garden
I need a diagram to rebuild the carb for my 67 250 inline 6
When you buy a carb. rebuild kit it will come with the diagram chart and spec to rebuild it.
Jun 10, 2010 | Cars & Trucks
It cuts out at full throttle.
Check the muffler and air cleaner for plugging. Try turning the H jet needle CCW about 1/2 to 3/4 turn which should make it 4-stroke at full throttle. Proper setting is for the engine to 4-stroke at full throttle, but immediately 2-stroke when cutting. (CW turning of H makes it leaner) See a Poulan servicing dealer for a rebuild kit. Be sure to check the fuel filter in the tank for plugging. Hope this helps!
Apr 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
LACK OF POWER . MACHINE WILL TICKOVER BUT CUTS OUT WHEN ACCELERATED. I HAVE CLEANED THE AIR FILTER.
Maybe get some carb and choke cleaner and clean the carb really well. It might have some varnish in the little holes that the fuel moves through. If you take the carb apart to clean it make sure you get a rebuild kit so you can replace the paper gaskets and the diaphram.
Let me know if this helps.
Thanks
roundo4
Jul 31, 2009 | Garden
1987 Ford Crown Victoria cuts off after running for a short time.
Mine did that same thing. I ended up having to buy a carb cleaning kit, and take the carburator apart and clean it out and rebuild it. It was really dirty inside it and since I did that I have had no problems!
Jun 10, 2009 | 1987 Ford Crown Victoria
Garden Logo
27 people viewed this question
Top Tanaka Garden Experts
john h
Nick Olsen
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
