Question about Car Audio & Video
Subwoofer problems I recently purchased a second hand subwoofer in a box. I then bought an amplifier for it, which I was assured had more than enough power. I tried wiring it up to one of my friends sound systems, through which he was running a subwoofer of his own fine, and the "Protect" light on his amplifier came on. No matter which way we wired it, the light came on. The only diagnosis from it was that there was a short circuit. After spending around 4 hours to set up my own amplifier perfectly, I tried it on mine. Still... Problems. My amplifier is (I think, according to the box) a 450-watt JBL mono-block (That's what the sales person told me, though it has 2 channels?). He also mentioned something about RMS after I asked if 450 watts was enough for a 1200 watt subwoofer. I tried wiring the subwoofer to my amp a few ways. I wired it parallel, running one channel to the first voice coil and the other channel to the second voice coil (Both voice coils are next to each other, not on opposite sides). After doing this, regardless of how much I turned the power input up or the level I set the bass to, all I ever got was a slight rumble from the subwoofer. I then bridged the channel and ran them to only one of the voice coils on my subwoofer... And it started smoking. The place I bought the subwoofer from have told me they don't do warranties on them as people keep trying to return ones they've blown up themselves. I'm too afraid to keep trying to get mine working in case I actually do blow it up... Any help would be much appreciated!!! P.S. HELP!
  • 2 more comments
  • KYWN Oct 09, 2007
    The subwoofer started smoking, I think it was coming from some fabric part. Yeah I know about positives and negatives, black and red, but this has totally got me beat. I'll go take a few photos later today and post them so you can see what's really going on.
    On the back of my CD player, it has two plugs (AV or RV? Or something like that), a positive and negative labelled "F" and another set labelled "SW" (This is where I plugged them in, assuming SW means subwoofer). They currently run to my amplifier to the "Input" labelled plugs. I had someone briefly look at this and they said it was correct; just making sure though. I've wired everything on the amplifier correctly, using a wiring kit I paid $20 for (Bear in mind I'm actually Australian, this was the first site I chose to seek help from)...
    I read some information off the internet and tried a new wiring setup. My amplifier has 2 channels. I ran one of the channels to one of the voice coils, and the other channel to the other voice coil. The subwoofer worked, though it did stuff all. Just tiny little rumbles. It didn't matter how high my bass went up, it only ever slightly improved. My stupid 6 inch speakers couldn't handle the bass up that high so that's not an option. Even turning the power input up on the amplifier did nothing, just made the lights on it flicker (I think because it was having it's power drained).
    Will post images soon... Thanks for your help!
  • KYWN Oct 09, 2007
    There's 3 little adjustable knobs on one end of the amplifier... One is "Bass boost", another is "LPF" and the last is "Power input". So I'm guessing from that last comment I should turn the LPF one up as much as possible? Sorry if I sound dumb, but how do I change the crossover settings to midrange? Thanks aswell to whoever added that last comment :)
  • KYWN Oct 09, 2007
    OK thanks, I'll go give it a shot now. As for the wiring, what should I do there? My amplifier has two channels and my subwoofer has two voice coils.
  • KYWN Oct 09, 2007
    Thanks heaps for all your help. It's only lunch time here, so I got tons of time to mess around with this. I'll e-mail you with the results.
    OInce again, thanks heaps!
  • 27 Answers
It sounds like you have a blown sub. Buy a new one from a reputable store and have them install it for you. That way if it doesn't work you won't have to pay for it. Also, be careful hooking a blown sub to a good amp. You can burn up your new amp that way.
Guy
TNT Pro Audio
Posted on Dec 18, 2008
  • 709 Answers
What started smoking the Sub or the amp?
Posted on Oct 08, 2007
  • 4 more comments
  • Greg Stokes
    Greg Stokes Oct 08, 2007
    The 450 Watt amp will drive a 1200 watt sub. Usually sub have a red and black lug to tie to to help keep the plus and minus right. You should also have plus and minus on your amp. Red is Plus and Black is minus. Follow the colors if you have them. Turn your gain down first after you get the system wired. Crank the gain up unitl you get distortion and turn it back a little. Tune your crossover downto 50hz or less.
    'I sincerely hope this helps you. I am running blind since I am not on the scene with you. It may help if you send me a picture of the terminals on the amp and of the terminals of the sub.
  • Greg Stokes
    my email is Repairtech@playstationclinic.com
  • Greg Stokes
    Greg Stokes Oct 09, 2007
    Ok Mate,
    Try adjusting the crossover settings to midrange. Also set the Amp to Run LPF or Low pass Filter. You may be cutting your bass out with the High pass Filter, or crossover.
  • Greg Stokes
    I think turning the LPF low pass filter up is a good thing. You should be able to start and get good bass with the LPF turned fully Clockwise. If you want you sub to play nothing but low frequency bass, you crank the LPF counterclockwise
    Bass Boost is something I would adjust during testing with music playing. Start the music, and start turn it up until you get distortion, then turn it back a little till the distortion goes away.
    Power Input is not familiar , but best guess is to adjust it to midrange. midrange is halfway between Fully Clockwise and Fully Counterclockwise.
  • Greg Stokes
    Ok Mate,
    This is the right way to hook up a Dual voice coil.
    Red wire + to Coil 1 +
    Coil 1 - to coil 2 +
    Black - to Coil 2-
    You should have a diagram at the terminal to show where to hook up a bridge. If not let me know. You amy have to do this.
    Channel 1 + to coil1 +
    Channel 1 - to Channel 2 +
    Chqannel 2 - to Coil 2 -
    jump a wire from coil 1 - to coil 2 +
  • Greg Stokes
    Ok mate, good luck, I am signing off, it is after midnight and gotta sleep now. I live on East coast USA in South Carolina.
Good afternoon, I recently bought a SA VE325 speaker set it contained a subwoofer, 4 little boxes and a mid-large box which you haeb have tpo piuyt above uyour tv. Now the problem is we have no cCENTER to...
Hello there looking at the manual i would assume that the mid-large box is actually your centre speaker.
Did you mean that there are no connections left on the back of your amplifier? For a centre speaker this system uses all passive speakers apart from the subwoofer which has a built in amplifier for just the subwoofer, your hifi or home cinema amplifier would need to have at least 5 separate channels to operate the centre speaker as well as the front and rear speakers.
Ideally you would need a 5.1 channel or 5 channel amplifier with subwoofer pre output, any would do but to make things simple one with a digital optical or coaxial input would be best as this can easily carry multi-channel audio with just one connector.
The other alternative if your amplifier does not have a centre speaker output are:
· to get another basic mono stereo amplifier to power the centre speaker on its own however if your main amplifier does not have a pre out connector for a centre speaker you will have to change the volume independently on both amplifiers
· don
Aug 27, 2011 | Sony SA-VE325 System
Tip
Car audio installation... important
when installing a sub woofer and amplifier to your vehicle always make sure that you also install a wired fuse in between your battery and amplifier without this problems may occur...
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jun 03, 2010 | Car Audio & Video
No sound from subwoofer
If your subwoofer does not work on your altec lansing speakers,
more than likely you blew the subwoofer amplifier board.
I have an ADA-885 system and bought it brand new back in
November 2000 and has been flawlessly operating great up
until this past month when my subwoofer went out but my
"satellite" speakers kept working. After disassembling the
subwoofer box I first noticed that the subwoofer amplifier
board is seperate from the rest of the grouped boards for
the dolby and satellite speakers. The subwoofer box is
designed to use the air from the subwoofer to actually
cool the amplifier boards inside the unit, great feature
until your subwoofer goes out, that is when your main
amp will more than likely fail soon after the sub amp
fails, as it uses the air from the subwoofer to keep the
amps cool. I know this might be an older post but
hopefully I can put it in the right category to hopefully
be able to help someone out in the future.
You can test the ohms of the speaker with a multi
tester. It's a dual voice coil speaker, 6 ohms each.
Well my system is broke and needs another
subwoofer amplifier board so if anybody reads
this and has this subwoofer, I need my sub amp
fixed ! or if you have the subwoofer unit maybe
and nothing else to go with it but the subwoofer
lights up, give me a jingle, I'd buy it from you !!
Jul 23, 2011 | Altec Lansing ADA 885 Computer Speakers
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Subwoofer thumping when turn on
Your subwoofer is not getting enough power, or it is grounding out due to a bad connection. What is powering the subwoofer? You might want to consider buying an AC to DC power inverter and a car amplifier to power your subwoofer. You connect the AC/DC inverter to your amp the same way you would in your car (+) to (+) and (-) to (-). The only other thing you will have to do is run the remote wire to the (+) on the amp. You can buy the AC/DC inverter at radioshack for $49.99, and all you really would need is a 200watt max amplifier and that would cost you about $10-$20.00 for a cheap one.
Feb 24, 2008 | Audio Players & Recorders
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
Subwoofer Line In/Out Mix-up
I had a problem with no audio and I recently found the fix. When the sub still worked and you turn it on you hear one relay click and then about 5 seconds later a second relay clicks and the audio comes on. The problem I had lies with that second relay. When you take the case apart there are 4 circuit boards. The big board with the two big blue capacitors is the main board. Well next to the two blue capacitors is a blue relay. That relay had a pin that came un-soldered from the circuit board. I re-soldered that pin and the sub works just like new. If you go here http://www.eserviceinfo.com/downloadsm/20627/sony_sawm500.html you can find a free service manual that has the wiring schematics for the amp. Hope this helps!
Nov 10, 2007 | Sony SA-WM500 Subwoofer
Subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Sep 14, 2007 | Polk Audio CSi40 Center Speaker
Car Audio & Video Logo
363 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
