Detrola km837 looking for a on/off volume rotary knob for km837
2 Suggested Answers
SOURCE: need to replace needle or
eat **** muddafuka
Posted on Sep 10, 2008
I cannot open the CD door on my Detrola KM837 4 in 1. I push the open button, sounds are emitted like it wants to work, but does not. Any suggestions?
agree with a small hole trick... but don't leave the drive ever empty. Use i.e. dummy CD media always. When you need it, just replace, spin your DVD, than put DUMMY back in the drive. Don't believe? Just try. :-)
proizvodnja raunara prodaja laptopova popravka kompjutera pc servis...
Sep 26, 2016 | Computers & Internet
Can i use a crosley stylus in my detrola km837 record player
Stylus will only fit into certain cartridges. You have two options here. You can look up the cartridge number and make on your Detrola. It should be on the cartridge somewhere. Then search for the stylus. Or you can remove the Detrola cartridge and fit a new cartridge and stylus. As long as the cartridge will fit into the arm of your deck, plus it's the right type - ie: magnetic if the old cartridge was magnetic! Or ceramic - again if the old cartridge was...
Then you can use any make or model cartridge you want. As the quality of the sound can be improved - albeit paying more money for it - by having a good quality cartridge and stylus, it might be best in the long run to change the cartridge.
Jul 15, 2015 | Crosley Audio Players & Recorders
I bought a Detrola KM837 second hand for my mom for Christmas, it came with no manual. The turntable I figured out from other posts, haven't tried it but I think that it would work. But my problem is the...
Very often a small belt has fallen off or broken. A look inside should locate it. To find a replacement belt, just measure the diameter of the old one in MM and then put the words "drive belt --MM" into Google. Select the size close to yours.
Oct 27, 2013 | Audio Players & Recorders
When I adjust the volume, I'll turn the knob, for instance, counter clockwise to turn it down. It will go down a couple digits and then may go up again.
hi richard, seems as if your rotary volume control internal switch pins are wearing out. this is a typical problem on many units that use rotary/digital encoder volume controls. before replacing the control clean the face pins, or have the pc board checked for moisture damage, or have the solder joints checked on the volume control. cheers.
Jun 23, 2012 | Kenwood KDC-322 CD Player
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
Need free owner's manual for a Detrola record player Model KM837
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Feb 22, 2009 | Audio Players & Recorders
unable to follow what is wrong.
are you talking about the tonearm or a lever at the power switch?
Jan 25, 2009 | Crosley CR248 Turntable
The rotary volume knob on my DEH 9400MP head unit has stopped working. this also happened to my friend's. the steering wheel remote still works. is this common? can it be fixed please?
Although I can't check this fix works for 1 month, a really simple explanation and fix was offered.
The rotary knob/control has 2 contacts, which when the knob is rotated c/w or anti-c/w it generates a pulse. The diagnosis is that as the remote still works, the PCB & volume circuit is fine. What is likely is that the 2 contacts/switches have become dirty or clogged.
SUGGESTED FIX: Take head unit faceplate apart to access PCB & rear of rotary control (4 screws). Spray WD40 into rear of volume control and rotate liberally to clean contacts. Dry of with lint free cloth, tissue or air dry.
I am confident this will work and the volume control will function again.
Sep 27, 2008 | Pioneer Car Audio & Video
49 people viewed this question
 Grubhead
Grubhead
