Question about HP Pavilion dv6-1030us Notebook
Primary internal battery error 601
Replaced internal battery and still receiving 601 battery error
4 Suggested Answers
  • 8909 Answers
SOURCE: I have an HP Dv7-1133cl that is giving me a error
It is called the Cmos Battery and if you browse www.insidemylaptop.com you will find how to change it.
Hope that helps.
Posted on Dec 31, 2010
  • 6771 Answers
SOURCE: hp dv7-1245dx error 601
Go in to bios and reset to factory default.
Posted on Mar 27, 2012
  • 6771 Answers
SOURCE: internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Posted on Jun 16, 2012
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
HOW DO i FIND THE NUMBER OF THE PRIMARY INTERNAL BATTERY FOR MY HP LAPTOP G70?
http://www.ebay.com/itm/like/110970146238?lpid=82 This is a link to USAPress for the internal BIOS battery fir theG70. I have used these folks for BIOS batteries for a couple of years and always had great service.
Sep 30, 2014 | Port Designs Replacement Laptop Battery...
HEWLETT pACKARDHOW DO I CHANGE A PRIMARY INTERNAL BATTERY FOR MY LAPTOP?
You need the service manual
But here is the quick bit
Remove the battery:
1. Turn the computer upside down on a flat surface, with the battery bay toward you.
2. Slide the battery release latch 1 to release the battery.
3. Pivot the battery 2 upward and remove it 3 from the computer.
The full service manual is available here
http://www.hp.com/ctg/Manual/c01573159.pdf
Sep 30, 2014 | Computers & Internet
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
Internal battery error 601 is displayed what is solution
1. This error is about the primary (main) battery, not the small CMOS one..
2. You may remove the primary battery from the laptop and use the laptop as a desktop using only a power cord. The battery doesn't have to be installed in the laptop and the error shouldn't be coming back then..
I would upgrade the BIOS first, it could be a bug and a newer BIOS might fix it..
Oct 13, 2013 | HP Pavilion dv7-1129wm Notebook
601 error message
Hello.
I am sorry that you are experiencing this error message. It generally indicates that your measured storage capacity in your primary battery is less than 25%. What this means is that your primary battery (601 indicates that it's primary) can only keep a 25% charge. To keep this quite simple for you, please attempt the following.
* Unplug your power cord.
1.) Start up your Laptop and hit the ESC key immediately.
2.) Press F2 to get into Systems Diagnostics.
3.) Select Battery Test. * Now, plug in the power cord.
4.) Start Battery Test.
The battery test will give you a STATUS. If you see the following;
- Calibrate: This means that your battery is functioning correctly but it is in need of calibration. Select the automatic calibration option.
- Weak: From here, please get a new battery to ensure that your getting adequate power supply to your laptop for use.
- Replace: Replace the battery.
- No Battery: If there is, indeed, a battery inserted. Remove it, check for dust/dirt and wipe it clear. Insert the battery and see if it works now.
- Unknown: Try to download all available updates from HP Support Assistant.
Feb 09, 2013 | HP Pavilion ze2000 Notebook
Internal battery error 601 hp compaq 6735s laptop
Jun 16, 2012 | HP Compaq 6735s Notebook
HP Pavilion dv6-1030us Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
