Question about Lockjaw Bosch Rs10 34'' Reciprocating Saw Blade System
Lockjaw blade holder stuck open
Where can I get a blade holder for a 52" fan?
  1. Fan Blade Holder - beso.com‎
    Adfans.beso.com/‎Electronics
  2. Health & Beauty Supplies
  3. Collections
  4. Brands & Stores
Search Results
    Ceiling Fan Blade Holders ' eBay
    www.ebay.com/bhp/ceiling-fan-blade-holders
    eBayThis is a ceiling fan blade arm (blade holder) from a Casablanca Ceiling Fan Company Airflow La Verne 52" ceiling fan model 1050-9. It is in good, working ...
    Fan Blades & Arms - Home Depot
Dec 29, 2015 | Dryers
Portercable 737 tigersaw can't keep a blade in the quick latch
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Mar 08, 2014 | Porter Cable Variable Speed All-Purpose...
Unlock trunk
you can try to go threw your back seat and use a big flat head screw driver to pry lockjaws open
May 24, 2013 | Hyundai Elantra Cars & Trucks
My mower engine was fine last time it was used. This time it is running poorly and very rich. Using excessive fuel. Only runs correctly when fuel is running out. The air cleaner is clear, the governor is...
The carburetor has a problem. You can take off the carburetor with a 5/16 socket and a 3/8 socket. Take off the air cleaner cover and remove the air filter. Then remove the air cleaner housing. This is three bolts that can be removed with the 5/16 socket. Take care not to damage the gasket that is behind this. Then the fuel line needs to be crimped. You can do this with lockjaw pliers. Then use a set of regular pliers and take the fuel line off. After this the carburetor has two more bolts that holds it on. They can be taken off with the 3/8 socket. The fuel bowl nut can be taken off with a 1/2 in socket. I would take it off and see if there is anything inside of the fuel bowl after removing it from the engine. If you see a round piece of metal in the fuel bowl then it has dropped a welch plug and the carburetor will need to be replaced.
Mar 31, 2011 | Briggs & Stratton Garden
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
Blade stuck in reciprocating saw
The pin is probably stuck in the blade. This happens from time to time after they get dirty. Take some WD-40 or some other type of penetrating oil and spray a little in the blade holder while working the release lever. It will probably free right up.
Apr 24, 2010 | Craftsman 8.0 amp Reciprocating Saw
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Oct 27, 2009 | Stanley Hand Tools
I have a Kenmore Elite Dishwasher. The water comes in and gets drained properly but the spray-arms don't seems to turn. I have cleaned the mesh but no change. Some people with similar issues have...
you can replace the impeller, it requires purchasing the part, removing the motor/ sump assy from the d/w( or uninstalling the d/w and flipping on its back) the motor does separate form housing with 1 screw and a twist. new part(s) are installed and reassemble,
Mar 24, 2008 | Washing Machines
Lockjaw Bosch Rs10 34'' Reciprocating Saw  Blade System Logo
59 people viewed this question
Top Lockjaw Saws Experts
Tom Chichester
ray gallant
Are you a Lockjaw Saw Expert? Answer questions, earn points and help others
