Question about Stairmaster Exercise & Fitness
I notice lately when on my personal climber hear squeaking noise on bottom of chain. Can I use WD 40 oil?d oil 40 to
  • Stairmaster Master
  • 914 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The manufacturer actually suggests using a 30W motor oil to lubricate the chains.
Preventive Maintenance Video for Stairmaster Stepper SC916
This video is covers preventive maintenance on your Stairmaster SC916 Stepper. Following a good preventive maintenance schedule will reduce equipment down times and repair costs.Due to the workout your equipment gets from use, they can become dirty over time.
Inspect the heart rate grips (if equipped) and make sure there is no accumulation of sweat on or around the contacts. A non-abrasive cleaner can be used on the contact heart rate grips daily.
Inspect all the shrouds and ensure they are securely fastened and no cracks have developed. Use of abrasive cleaners can create cracks in the shrouds or cause them to become brittle.
Inspect the cup holder shroud. Make sure there have been no holes drilled into the shroud for the purpose of allowing sweat to drain and preventing accumulation. The proper method of dealing with the sweat accumulation in the cup holder shroud is regular cleaning of the area.
Once you've made all the shroud inspections, step up onto the pedals. Feel the motion of the unit and verify smooth operation. Listen for irregular noises. A good maintenance routine allows you to recognize how a unit in good operating condition should feel and sound.
Next, inspect the step chains. The links of the chain should move freely. The chains should be lubricated on a 3 month basis with 30w motor oil.
Inspect the pedal hardware. Each step the user takes, there is movement of the pedal hardware. Ensure that all the snap rings are secure to their shafts and none are working free. If a snap ring is not secure, it's possible that damage to the pedal can occur or it could fall off during exercise and possible injury could occur.
These are the main points for preventive maintenance.
Posted on Oct 01, 2015
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I have Tectrix Personal Climber. The on/off
No I believe that switch is the problem your Tectrix PC Is part of Cybex International and their phone # is1-800-677-6544 now if they do not have this part then call National Gym Supply @ 1-800 496-7278 the Personal Climber and The Climax ( commercial unit) uses the same switch assembly.
Posted on Mar 13, 2010
SOURCE: My Tectrix Stairmaster Personal Climber is
Mine did that and I had to have the clutch replaced. The cost to order a part and have a tech come out to perform the repair was about $200.00
Posted on Jan 04, 2011
What is causing a creaking, squeaky noise to come from the right pedal on my sc5?
Your transmission chain and reduction pulley, and or step chain need to be checked.
It could just be the transmission chain is on just a little too tight, causing the creaking or that the step chain/s just need a little grease on them (which is likely the culprit to any creaking).
If you find you need need any further assistance we would be happy to help you out :) by chat at www.sportsmith.net or by phone at 888-713-2880
We look forward to hearing from you if you need us!
Aug 12, 2015 | Stairmaster Exercise & Fitness
Bernina 801 squeaking squelling noise
Needs oiling and cleaning. Use good quality sewing machine oil, NOT 3-in-1, WD-40, or cooking oil.
Jan 06, 2013 | Sewing Machines
Dryer squeaks
the rollers or belt idler may be corroded, use mineral oil or special bearing lubricant. DO NOT USE WD-40 OR 3 IN ONE OILS. you may find that they may need replacement.
Feb 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
Chain
Yes, All motorcycle chains currently being manufactured use Buna-N (Nitrile) rubber for their o-rings and x-rings, and all these manufacturers recommend kerosene as a cleaner. Here's the formulation of WD-40: 80% Stoddard Solvent (that is similar to kerosene) 20% light lubricating oil, and a bit of fragrance. Here's the compatibility of Stoddard Solvent with rubbers and plastics: Good Compatibility (OK for both static and dynamic seals) Buna-N (Nitrile) Chemraz Epichlorohydrin Fluorocarbon Fluorosilicone Kalrez Nitrile, hydrogenated Polyacrylate Teflon, virgin Mixed Compatibility (OK for static seals, but not for dynamic seals) Neoprene Vamac Fair Compatibility (OK for some static seals) Polysulfide Polyurethane, millable Poor Compatibility Butyl Ethylene-Propylene Hypalon Natural rubber Silicone Styrene Butadiene Consequently, WD-40 is safe and effective as a chain cleaner and corrosion inhibitor. Link: http://www.efunda.com/designstandard...dard%20Solvent If you clean with a soft brush and WD-40, and plan to follow-up with a chain lube, you can reduce chain lube sling-off if you first remove the oil residue that WD-40 leaves. This residue seems to prevent some chain lube formulations from sticking well to the chain.
Nov 10, 2008 | 2005 Vertemati S570
Chain
Yes All motorcycle chains currently being manufactured use Buna-N (Nitrile) rubber for their o-rings and x-rings and all these manufacturers recommend kerosene as a cleaner. Here's the formulation of WD-40: 80% Stoddard Solvent (that is similar to kerosene) 20% light lubricating oil and a bit of fragrance. Here's the compatibility of Stoddard Solvent with rubbers and plastics: Good Compatibility (OK for both static and dynamic seals) Buna-N (Nitrile) Chemraz Epichlorohydrin Fluorocarbon Fluorosilicone Kalrez Nitrile, hydrogenated Polyacrylate Teflon, virgin Mixed Compatibility (OK for static seals, but not for dynamic seals) Neoprene Vamac Fair Compatibility (OK for some static seals) Polysulfide Polyurethane, millable Poor Compatibility Butyl Ethylene-Propylene Hypalon Natural rubber Silicone Styrene Butadiene Consequently, WD-40 is safe and effective as a chain cleaner and corrosion inhibitor. Link: http://www.efunda.com/designstandard...dard%20Solvent If you clean with a soft brush and WD-40, and plan to follow-up with a chain lube, you can reduce chain lube sling-off if you first remove the oil residue that WD-40 leaves. This residue seems to prevent some chain lube formulations from sticking well to the chain.,,,
Nov 10, 2008 | 2004 Enfield Military
Chain
Nov 10, 2008 | 2007 Daelim Daystar
Chain
Nov 10, 2008 | 2005 Benelli TnT
Chain
Nov 10, 2008 | 1972 Aermacchi Sprint 350
Exercise & Fitness Logo
245 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
