Question about Dryers
Dryer turns off
My Kenmore Elite gas ryer has all of the sudden started to turn off during the dryong cycle but will come on from time to time during it as well. What to do
  • 1 more comment
  • Anonymous Feb 17, 2009
    DRYER SHUTS OFF IN THE MIDDLE OF A CYCLE; AT TIMES IT DOES NOT WANT TO START AT ALL. YESTERDAY STARTED MAKING A SCRATCHY NOICE WHEN ON. WE CHECKED THE VENTS AND CLEANED THEM UP 2 WEEKS AGO.
    THANK YOU
    My dryer shuts off in the middle of the cycle; at times it won't start at all. We checked vents. Yesterday it started making a scratchy noise when on; so I had to turn it off.
  • dinod Apr 13, 2009
    Dryer randomly shuts off and will not start. Vents are cleaner dryer will not restart for like an hours. Almost seens like it is overheating. When pressing start button cycle will not start.
Miele t440c, the dryer will flick the safey switch after running for about 5 minutes the light is blown inside the barrel, I have removed the blown bulb still the same problem
Posted on Aug 22, 2009
  • 290 Answers
Is the dryer shutting off completely or is the burner going on and off erraticly? If it is the burner you probably have a faulty coil on the burner. There are two electric coils mounted on the burner. You can buy both of them in a pack cheaper than buying one by itself. Remove the lower front cover and you will see the coils on the gas valve with wires going to them. Remove the wires and bracket that holds them down and install new coils. They are made so that you can't mix them up, they only fit one way.
Posted on Oct 08, 2007
  • Anonymous Oct 14, 2007
    Just wanted to follow up on your dryer problem and see what you found out.
    Thanks/Mike
SOURCE:
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Hi I have a kenmore elite oasis dryer. And all of a sudden it only will run for about a minute and then it shuts off. I tried turning it back on again and it does the same thing. Then after the third time...
The first suggestion I have for you is to simply run an Air Fluff cycle with no heat.
If the Air Fluff cycle runs okay then the problem is most likely with the thermistor.
You can try to run the dryer with the vent hose off and see if there is a difference.
Oct 07, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
I have a kenmore elite gas dryer model 11070952990 that won't start at all.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore elite gas dryer will not heat
clean out any lint build up in the exhaust vent tubes
the moister sensor will put the heat in check if clogged up
Aug 01, 2010 | Kenmore 63942 Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer handle replacement - Kenmore Elite
E-mail me the model number of the dryer and I will be able to find you the information you need. [email protected]
Apr 08, 2008 | Dryers
Dryer has power won't start cycle
Hi, check first the power outlet , if still does not turn and motor humming during starting time , test the capacitor with multi tester, disconnect two wire of capacitor if not reading replace capacitor .
Jan 20, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
891 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
