Question about Refrigerators
How to adjust temp on simpson sr235a - Refrigerators
Excessive bowl swing on spin cycle - machine cuts-out. SIMPSON 22s650. tried adjust load balance but still wobbles to cut-out. Sometimes OK with an under loaded light load.
Sounds like it needs new suspension rods. One on each corner. The spring on the rod gets weak causing excessive bouncing & swinging.
Jul 17, 2017 | Simpson Washing Machines
Setting our machine on warm , but the water s hot , both hot & cold taps are fully turned on .
Check your hot/cold inlet valve and solenoid. It sounds like your cold water side of the valve is stuck shut. The valve is found by following the inlet hose right to it. Also, do you have a domestic well as water supply? Sometimes fine sand from a domestic well will plug the valve screen. It is also possible that other mineral would plug the screen. These things would happen gradually, though, not all at once.
Feb 02, 2017 | Simpson Washing Machines
My Simpson ezyset 6kg washer won't empty or spin after it w eat out of balance
check the lever to microswitch adjustment for the balance
normally it is also the lid open microswitch and if the unbalance was sever enough the lever will be on the wrong side of the switch
Dec 27, 2016 | Simpson Washing Machines
Machine will not turn on no lights simpson swt554 top loader
check the lid isolation micro switch for adjustment
Mar 29, 2015 | Simpson Washing Machines
Swt955sa simpson topload washers but wont spin
i would suspect the motor brushes or something related too the motor
silly question but you do have spin switched on
i dont know your specific machine
but most modern spin speed adjustment knobs
have a setting 'no spin'
ive fixed four last week same thing the wee old lady and three familys .. same issue spin simply switched off
Mar 09, 2015 | Simpson Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Nov 08, 2010 | Siemens Washing Machines
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
