Question about Dayton Permanent Split Capacitor Motor Fan
Wiring diagram for 2hp 3ph wattrimmer - Dayton Permanent Split Capacitor Motor Fan
Grizzly 1 1/2hp motor wiring diagram
Page 54 and 55 of this manual should solve the problem.
http://cdn0.grizzly.com/manuals/g1022sm_m.pdf.
Jan 09, 2014 | Grizzly Saws
Wiring diagram for terminal board on 2hp 240volt water pump waterflow type 90L-2
Wiring diagram should show on side of pump.
Copy following links for help identifying wires and testing start coil vrs run coil on multi-speed motors.
http://waterheatertimer.org/images/Motor-capacitor2-800.jpg
http://waterheatertimer.org/images/Motor-wiring-500.jpg
Oct 05, 2012 | Hardware & Accessories
Wiring diagram for jandy flopro pump
look on side of motor for low or high wiring
Jun 21, 2012 | Jandy Flopro Medium Head 2hp Up-rated...
We have a Problem with a "JTM-4VS, 9" x 49" Table, R-8 Taper, 3HP, 3Ph, 230/460V" milling machine. We will need for the variable speed head assembly the part no. 114 which is figured in...
draw bar ...you can buy them from enco or msc for about $20-$30. Give them a call and tell them the machine you have...mention you have variable speed.
Apr 30, 2011 | Jet JTM-4VS, 9" x 49" Table, R-8 Taper,...
NEED a wiring Diagram for a Dayton 3hp motor model # 5K967M is there anyone out there that can help me
you don't need a wiring diagram for 3ph. this motor is single phase. either 120 or 240v. you just need to fing out what power you will power it with and read the inside cover for the wiring box on the motor. given to you by an electrician w/35 yrs experience.
Mar 08, 2011 | Kitchen Ranges
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
Bought A new daton fan motor to replace the old one and it spins backwards now
You didn't give any model numbers so there is little to go on, but typically a motor spinning backwards has been wired incorrectly, particularly if it is a 3ph motor. There could be other causes but in 3ph motors this is the most common.
May 18, 2010 | Heating & Cooling
How do I wire a Simer 2hp pump for 220v?
If it is capable of operating on 220, a diagram should be on the inside of the cover plate or the on the nameplate
May 29, 2010 | Simer ACE5S ACE5S Pump Well 1/2HP Ace 5S
Dayton Permanent Split Capacitor Motor Fan Logo
15 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
