Question about Poulan 18" Chainsaw Chain Model Ppb4218
Have populan ppb4218 gas saw. the fuel filter is not atached to a line. How do I correct
Where is the line that pass through the tank to which the fuel filter is attached
  • 7 Answers
SOURCE: my poulin chain saw wont run
Can you get it to run at all? if not pull it a few times and check if the plug is wet. Let me know
Posted on Feb 25, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a poulan 305 pro chain saw were do the 2 fuel lines go?
Find your model nuber here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The drawing containing your fuel system is as good as it gets. If you need more help contact PoulanPro.com. HTH
Lou
Posted on Sep 18, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan 2450 thats not getting any fuel, I
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Typical fuel system:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best.
Poulan.com
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Posted on Nov 28, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
  • 4088 Answers
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Posted on Jul 16, 2010
GAS line diagram for Poulan 2050 Chain saw
The gas line goes from the gas tank to the carburetor and probably passes through the underside of the handle. The correct diameter hose is very important as it is used to form a compression seal with the gas tank using a coupling that connects to the siphon filter with a short length of tubing.
Feb 21, 2015 | Poulan Wild Thing 2375 18" Gas Chain Saw...
HUSQVARNA 41 CORRECT FUEL FILTER TO BIG FOR MY FUEL LINE IN TANK--DO I NEED TO GET BIGGER FUEL LINE??
you can get saw specific parts from a Husq. dealer or you can make shift something to get you by. the key is to make sure the hole in the tank is slightly smaller then the diameter of the hose to ensure there is no air leak there. I drill the tank hole out a size at a time until I have to force the hose in that will fit snuggly on the carb inlet then replace the fuel filter with one that fits the line
Mar 20, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
I have a 340 Air Injection Chainsaw. We made sure it has gas/oil and chain saw oil. We get it started but it won't stay on? What are we doing wrong.
If it has an air filter make sure it is clean, also check the gas filter in the gas tank,
sometimes it will get gummed up and will pass very little fuel, it can be pulled out
by making a hook on the end of any wired coat hanger or stiff wire, once you pull,
it out remove the fuel filter , put the fuel line back in, make sure it is submerged
in the fuel, if it keeps running, just replace the fuel filter, the gas tank will have
two lines going to it, normally only one has a filter, also make sure the lines are
intact and don't have any cracks or breaks. make sure your gas to oil ratio is
correct. most chains will have it written on the chainsaw, or check your user's
manual. 40:1 ratio on older models , on newer models 50:1 good luck!
Jul 02, 2011 | Husqvarna Garden
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out...
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Dec 29, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Getting my new fuel lines in correctly from gas tank to priming bulb & from gas tank to carb.
on weedeaters,chain saws. most are the same.
line with little filter in gas tank goes to carb. line out of carb to primer bulb
line from primer bulb to gas tank
Jun 24, 2010 | Garden
Help me to locate the fuel filter and fuel pump in the kia sedona
start of at the gas tank look under neath there are some black lines running towards the engine follow it to a small gold color that ataches to the line you are following that is the filter the pump is in the gas tank you need to drop the straps at the tank to bring it down
Nov 05, 2009 | 2003 Kia Sedona
I have a Poulan 2150 2.1 chainsaw. I have no manuals. All of the fuel lines are dry-rotted and need to be replaced. How can I do this myself?
An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
“2150 Gas Saw Type #” (the dash number from your serial number). May also be Predator or Woodsman.
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
Take good notes and a some digital photos with as much undisturbed detail of hoses and routing as possible.
Try your local chainsaw seller/mechanic for fuel hose. Take a short length sample, there may be different size hoses. All need be fuel resistant.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan Garden
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Poulan 18" Chainsaw Chain Model Ppb4218 Logo
49 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
